Recommendations on 12VDC power supply
0 Members and 1 Guest are viewing this topic. Read 2072 times.
« on: 22 Jul 2013, 10:24 pm »
Any recommendations on a 12VDC power supply? Something with a standard cord. I need it to have terminal connections because the other end is going to have terminal connections. I just need to hard wire it and not worry about cutting off connectors.
Phil A
Re: Recommendations on 12VDC power supply
« Reply #1 on: 22 Jul 2013, 10:29 pm »
I was almost going to get one of these to mess around with (you need the safety cover too) - http://www.newark.com/sola-hevi-duty/sls-12-034t/power-supply-linear-12v-40-8w/dp/93K6598    Saw them cheap on E-Bay once.  I guess at some point I may look at it again for the HAL MS-2 Music Server.
« Reply #2 on: 22 Jul 2013, 11:57 pm »
Anything cheaper?
Phil A
« Reply #3 on: 23 Jul 2013, 01:43 am »
Anything cheaper?
You looking for a linear power supply or just a 12V one.?  Parts Express and MCM Electronics probably have plenty of cheap ones.  I actually can look upstairs.  I might have one laying around somewhere but you would have to cut off the connector.  I've seen the one I posted for about 60% less on e-Bay at least once.
Phil A
« Reply #4 on: 23 Jul 2013, 01:52 am »
There's no shortage of their products on e-Bay.  I started looking at 5V ones way back when I had the HDMI audio de-embedder (vs. the Meitner DAC) as the main thing I used for SACDs into the DAC.  I have 3 of those (5V) now (actually have a 4th I bought from a surplus place and I soldered a connector on it - never tried but I made it for Karl whom you got stands from).  I'll use one for the Squeezebox Touch and maybe I'll get DACs or a DAC for a spare system and use another and have a spare.  Below are some links on e-Bay:
http://www.ebay.com/itm/Sola-Hevi-Duty-Power-Supply-SLD-12-1010-12T-SLD12101012T-12V-VDC-1-Amp-New-/300860482451
http://www.ebay.com/itm/SOLA-HEVI-DUTY-Linear-Power-Supply-/290714534063?pt=LH_DefaultDomain_0&hash=item43afefc0af
http://www.ebay.com/itm/EGS-SLD-12-3015-05T-SOLA-HEVI-DUTY-POWER-SUPPLY-SN-00190607-NEW-IN-BOX-/271156232193?pt=LH_DefaultDomain_0&hash=item3f222bc001
Phil A
« Reply #6 on: 23 Jul 2013, 03:27 am »
Please check if you have one or two.
You still have that old stereo receiver as well?
Phil A
« Reply #7 on: 23 Jul 2013, 03:59 am »
Yes - Someone (Karl) told me he wanted it a while ago.  I have not talked to him in a couple of months.
rollo
  • Rollo Audio Consulting -
« Reply #8 on: 23 Jul 2013, 01:27 pm »
Stancor from Allied Electronics. Used with ART DIO very good and inexpensive.
charles
