0 Members and 1 Guest are viewing this topic. Read 10135 times.
Look for the one that fits the best. The two most important aspects are the top tube length and head tube length, imo. All of the below are nice bikes, and will have more than adequate components. The SL3 probably has the nicest specs, which is why it probably costs the most too. Again, all will be more than sufficient. While I am a big fan of disc brakes, it may be overkill for the intended use. Unless your plan to ride to work in less than ideal conditions or during the winter months.Sure it goes without saying, but make sure the bike has eyelets if you plan to use or need a rack. Personally, I'd lean toward the models which have carbon fork legs. Without trying to stereotype, it should take a little bite out of the road and give a tad more comfortable ride. Let us know what you end up with.
chip, do you think you'll be limiting your riding to commuting or could this be a first step on a journey?If, for example, you get keen on road riding as recreation or perhaps take to riding with others, you could find yourself looking at a very different bike to the ones we're talking about.Bike running gear is pretty reliable and so long as it's given reasonable maintenance it'll last forever on low mileages, so there's probably not a huge amount of difference in bikes of this class.A second hand bike can be a good option while you're deciding your ultimate needs. I say this partly because 2nd hand bikes are cheap and it can be a good way to get a considerably lighter bike in the class you're looking at. Weight does matter not just for the amount of effort you need to put in but also because a lighter bike usually feels more responsive and well, more fun.
