Balanced XLR Interconnects for Bryston SST2 Amps
0 Members and 1 Guest are viewing this topic. Read 7781 times.
Samurai7595
« on: 29 Jun 2013, 01:02 pm »
I just ordered a Bryston 4B-SST2 power amp to use with my Linn system and ProAc speakers.
I'd like to go with a balanced connection between my Linn pre-amp and the Bryston power amp (roughly 2.5 meters).
Which cable(s) would you recommend?
The rest of my interconnects are Linn silver interconnects (balanced and unbalanced):
Balanced: http://www.linn.co.uk/all-products/accessories/silver-balanced-interconnect-cable
Unbalanced: http://www.linn.co.uk/all-products/accessories/silver-interconnect-cable
Elizabeth
Re: Balanced XLR Interconnects for Bryston SST2 Amps
« Reply #1 on: 29 Jun 2013, 02:48 pm »
I use a seven meter run of Kimber Hero from my Bryston Bp-26 to the Bryston 4B-SST²
It is good. i have no complaints about it.
So There
  • Brystonized
« Reply #2 on: 29 Jun 2013, 04:02 pm »
Congratulations, Samurai, you'll love the 4B.
I use Bryston's XLRs. They're very well constructed and quite neutral and transparent. They will do custom lengths for you (have your dealer contact Melissa).
http://store.bryston.com/single_xlr.html
Rich
_______________
Whiney Napa Valley
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
budcook
« Reply #3 on: 29 Jun 2013, 04:55 pm »
Rich
_______________
Whiney Napa Valley
I've used a five meter pair of Bryston balanced cables since I got my 4BSST2.  IMO, Bryston cables are one of the best deals you can get.  You will have to pay much more money to get something better.
I have recently replaced them with 3 meter Cardas Clear Light because I got a great deal on them and I have an all Cardas system.  I'm putting my Bryston cables on eBay.  PM me if you are interested.
Bud
rmurray
« Reply #4 on: 29 Jun 2013, 05:00 pm »
 Bryston wires( balanced) :thumb: have been great and at a realistic price. They are silver coated OFC Van Damme with the very high grade professional Neutric ends   :thumb:
Samurai7595
« Reply #5 on: 29 Jun 2013, 06:53 pm »
Bud
Hi Bud,
I appreciat6e the offer but I re-measured and will only be needing 2 meters (6.5 feet).  I'll check with the Bryston store.
Sam
budcook
« Reply #6 on: 29 Jun 2013, 07:20 pm »
Hi Bud,
Sam
No problem Sam.  I've got some XLR's so I should probably cut up my cables and re-terminate them.
95Dyna
« Reply #7 on: 30 Jun 2013, 02:31 am »
I'm using WireWorld Silver Eclipse 6 2.5M bp26>7B SST2's with great results.
mv038856
« Reply #8 on: 30 Jun 2013, 09:47 am »
Hi,
I am more "down to earth" with my cabling: My thinking is "if it is right for the studio, where the recordings are mixed, then it should be fine for me". Therefore, I am using the highest quality Sommer Cable studio XLR cables with the best available Neutrik XLR plugs. I feel this approach being very close to what Bryston is doing with its line of cables.
Cheers!
Markus
Chicago
« Reply #9 on: 30 Jun 2013, 10:02 pm »
Another vote for Bryston but that's my ear.  Try a few and see what you like.  If you don't have a local dealer that carries them at <$300 pr for a 2m run you will not be out much on a resale.  As someone mentioned they are like all Bryston gear neutral and transparent.
Good Listening,
Mike
Vipers
« Reply #10 on: 1 Jul 2013, 06:33 pm »
Congratulations on ordering the 4B Samurai, as for cables I have tried many over the years with Bryston but always come back to Atlas Cables, the Hyper XLR's are reasonable value but I now run Atlas Mavros XLR's which sound superb, works brilliantly in an all Bryston rig, very clean, transparent and effortless, well worth a try.
drummermitchell
« Reply #11 on: 1 Jul 2013, 10:50 pm »
As the speaker cable post I went from Cardas GRC's to Bryston,don't miss a thing.
Grit
  • - Garrett
« Reply #12 on: 2 Jul 2013, 07:46 am »
There are SOOO many options for cabling, I'd go nuts trying to figure it all out. What I wish we had was a review of cables, compared to each other. Thus, if I currently use cable brand "A", but *I* want my system to sound "brighter", cable brand "C" will do that.
I currently use Transparent Audio, but I have no thing to compare them to.  :?
alexone
« Reply #13 on: 2 Jul 2013, 06:22 pm »
Hi,
Cheers!
Markus
hi, Markus!
...that's what I'm doing too - using Sommer Cables 'SC-Square Referenz' (xlr) for my SP2/875 setup :thumb: these are quality cables at a reasonable price.
al.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #14 on: 2 Jul 2013, 09:07 pm »
mogami or canare xlr
