Audioquest Firefly
0 Members and 1 Guest are viewing this topic. Read 2550 times.
sugbob21
Audioquest Firefly
« on: 22 Jun 2013, 06:17 pm »
 :cry: is there a reason why my firefly works with my Mac laptop and not with my Mac Mini ? All i get is static.
ltr317
Re: Audioquest Firefly
« Reply #1 on: 22 Jun 2013, 11:50 pm »
I have had a similar experience.  I borrowed a Firefly to try on my Sony laptop and couldn't get it to work at all.
sugbob21
« Reply #2 on: 23 Jun 2013, 04:09 am »
It sounds great when it works , but I have become so frustrated with it I just took it out of my system altogether. I even purchased a firefly tail (not sure if that's what they call it), which is an extension for the firefly out of the USB but that does not help any. I really needed it on the mac mini and for that it's a flop.
srb
Re: Audioquest Dragonfly
« Reply #3 on: 23 Jun 2013, 04:26 am »
I assume you mean the Dragonfly?  Have you compared the Audio Midi Settings for the device on the Mini vs the Laptop?  Perhaps the default format is set to 192KHz?  Try 44.1KHz/16bit to see if you get any sound with that setting.
ltr317
« Reply #4 on: 23 Jun 2013, 04:25 pm »
I don't know what sugbob tried, but I tried every audio setting and device playback options and nothing worked.
sugbob21
« Reply #5 on: 23 Jun 2013, 08:05 pm »
 :D :D  Hi SRB Steve......went into audio MIDI and set it to 96 Khz and eureka its working so far.
And yes it is the Dragonfly and Dragontail although i have called it alot of other things recently.  So far so good.
thanks alot
sugbob21
« Reply #6 on: 23 Jun 2013, 08:07 pm »
ltr317....make sure u change the setting in the "utilities" audio MIDI setup.  i didnt even know about that one.
ltr317
« Reply #7 on: 23 Jun 2013, 11:59 pm »
I did that change and it still didn't work.  I returned it to my friend and borrowed a USB MyDac from another friend which works perfectly.
