Shorting plugs on Mapletree 2A/SE Linestage unused inputs?
0 Members and 1 Guest are viewing this topic. Read 4843 times.
rockadanny
Something like these:
These RCA shorting plugs are a dead short
http://www.takefiveaudio.com/mall/shopexd.asp?id=1416
1. OK to put these on my Mapletree 2A/SE Linstage?
    Any potential harm done?
2. Have you done this for better audio on your Mapletree or other pre?
    As per TFA:
Inserting these plugs will short-circuit the input and stop any RF noise from getting inside the circuit. With the shorting plugs installed you will improve the S/N ratio which can lead to a dramatic improvement in sound quality. If the inputs on your particular preamp use relays to short them when not in use these plugs will offer no sonic benefit.
WireNut
Re: Shorting plugs on Mapletree 2A/SE Linestage unused inputs?
« Reply #1 on: 20 Jun 2013, 06:17 pm »
Hmmm. Interesting that Take Five sells those now. I got this recipe off of their site about a year ago and that work great on my audio research LS7 preamp. Why they choose the 470 ohm resistor I don't know but they work fine.
The link is still up under DIY Recipes and tips. Cost me about $1.50 each to make.
http://www.takefiveaudio.com/mall/shopcontent.asp?type=RCA_Input_shorting_plugs
I've also used the dead shorting plugs in the past on a different preamp. I've never experienced any problems using either type. I don't use them any more because all my inputs are being used.
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 20 Jun 2013, 07:58 pm »
Good question about resistor. I use shorting plugs on all unused inputs to good affect. Quiet and hear more information.
charles
Speedskater
  • Kevin
« Reply #3 on: 20 Jun 2013, 08:30 pm »
I was just reading about a good pre-amp decades ago that provided shorting plugs so that when you turned the input selector past an unused input, you wouldn't get a pop.
SteveFord
« Reply #4 on: 20 Jun 2013, 11:03 pm »
Would this cure bleed-through with my tuner (using phono or CD, inbetween cuts you can hear the tuner)?
Speedskater
  • Kevin
« Reply #5 on: 20 Jun 2013, 11:31 pm »
No, it's for unused input jacks.
bleed-through is a different problem, that sometimes is hard to cure.
SteveFord
« Reply #6 on: 20 Jun 2013, 11:34 pm »
Okay, thanks.
I will turn the tuner off.
WireNut
« Reply #7 on: 21 Jun 2013, 12:10 am »
Hi Steve,
I have a couple pair you can have, If interested PM me and I'll mail them to you.
BTW, I Got my SFL-2 back up and running. I missed that sucker.  :D
I love see'n those 8 tubes glow again  :thumb:
WN
SteveFord
« Reply #8 on: 21 Jun 2013, 01:35 am »
Will do.
Congrats on the Sonic Frontiers - I stray every so often but that's a keeper!
SteveFord
« Reply #9 on: 10 Aug 2013, 08:55 pm »
Wirenut came through and sent me a care package of them and it cut the tuner bleed-through down to just about nothing.
Thank you so much!
