0 Members and 1 Guest are viewing this topic. Read 35476 times.
I could use a little help understanding the recommended power for the Ottavo which is 75 to 300 watts. Is the power at 4 ohms?What are the consequences of running these speakers at the lower end of this range?Given the range it seems most (reasonably priced) tube amps would not be recommended. Is that correct?The sensitivity of the Ottavo is 87db. How does that translate to amplifier power, the size of the room and speaker performance?Thanks!
Thanks, Rick. Just for reference I currently have a Pioneer A-27 integrated amp (180 watts @ 4ohms w/first 3 watts Class A) driving a pair of MTMs (RAAL and SB Acoustics) you designed for me a few years back. I also use a couple of subs in stereo. The setup is very nice but I'm looking to move to a full range floorstander and I keep finding myself looking at tube amps. My listening position is about 12 feet from the speakers in a living/dining room space and I typically listen at 80 to 85 db (C weighted). So, just for example, would a Mac MC-275 at 75 watts/channel drive the Ottavos well in my environment?
There is a myth that tube watts are greater than solid-state; however, that's simply not the truth. You can easily test for this by measuring one watt across the output of both a tube and solid state amp and measuring the level of the speaker's output. Some tube amps lack enough current capability as well. A good indicator of current capability is how close the amp comes to doubling its' output into four ohms versus eight ohms. Tube amps do clip differently than solid-state but the distortion is still there - just in a different harmonic structure. Some solid state amps clip with grace (little audible effect) and others not so tolerable - depends on the design. Hope this helps.
Rick,I agree it is a myth that Solid state is lesser than tube but why cant they build solid state amps with the same clipping characteristics as tube if that is what sounds better to a human ear (I believe during the famed Bob Carver Amplifier challenge, Bob tuned one of his Solid State amps - the M1.0t - to sound and clip like a tube amp)?Most solid state and some tube amplifiers manage to double their 8 ohm power when the load falls to 4 ohms but since most loudspeaker loads are reactive with impedances dropping as low as 2 ohms (sometimes even lower as with the original WATT) it might be better to look at the 2 ohm power delivery (RMS @ 20-20kHz) specifications as well. This is where tube amps struggle. So it best to look at the amps power delivery at your loudspeaker's nominal and minimum impedance.Some tube 'purists' claim Single Ended is the only way to go, and while there is a audible difference between Single Ended, Triode and UL configurations of tube amps I have never found any one configuration to sound so bad that it detracts from the enjoyment of music.
I have been in touch with Albert at spacetech lab, he is a great guy to talk too and have various designs that might fit you set up and budget.
Just saw this thread. Those are some outstanding looking speakers. I love the dual 8's and the tapered cabinet.
Veneer is beatiful Rick, what species is that?
