Ottavo
0 Members and 1 Guest are viewing this topic. Read 35475 times.
NORGATEoiler
Re: Ottavo
« Reply #40 on: 9 Aug 2013, 04:06 pm »
Very much looking forward to seeing the measurements on this. Probably looking to build these next year!
Jon
danny01
Re: Ottavo
« Reply #41 on: 10 Aug 2013, 07:09 am »
Jon
I'm curious to see the measurements as well. What are the physical dimensions of the speaker, specifically, how high is the tweeter?
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Ottavo
« Reply #42 on: 10 Aug 2013, 06:26 pm »
I hope to have all of the information on the website by the end of this weekend. The dimensions and layout will be a little different than the pictured speaker. My customer adjusted his cabinet dimensions and layout for his needs. The production cabinets will be 14" at the bottom tapering to 7-8" at the top. The height (minus spikes) is 40" and depth will be 14".
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #43 on: 13 Aug 2013, 04:06 pm »
I've added specifications and measurement graphs. See them here...
http://www.selahaudio.com/id299.html
jonbee
Re: Ottavo
« Reply #44 on: 13 Aug 2013, 04:20 pm »
That is one killer design for ~$5k!
bernardo
Re: Ottavo
« Reply #45 on: 13 Aug 2013, 04:38 pm »
Rick-
Are these set up so that one (meaning me) can take a listen? I havn't heard any of your floor standing models nor an Accuton or RAAL driver.
Carl V
Re: Ottavo
« Reply #46 on: 13 Aug 2013, 04:42 pm »
looks nice.....very nice.
Curious haw this contrasts with the tre supremo
Carl V
Re: Ottavo
« Reply #47 on: 13 Aug 2013, 04:51 pm »
Rick an acquaintance has recently purchased a nice big three way.
(it sounds & looks nice...not an AC member or Mfg. associated with AC.)
and he states that the XO design resistively shunts amplifier current around the driver.
"This gives the amplifier a less reactive, lower impedance load. It also
gives the crossover network a less reactive, lower impedance load.
Finally it provides the driver with a less reactive, lower impedance
source."...indeed his hovers around 3.0-5.5 ohms.
The Ottavo likewise has some low impedance swings.
Is this a reasonable approach?
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #48 on: 13 Aug 2013, 05:03 pm »
Yes - I don't believe anything else can touch it at the introductory price as well as much more than that.  :thumb:
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #49 on: 13 Aug 2013, 05:19 pm »
Rick-
Sure - let me know and I can arrange a listening session.
Bazinga
Re: Ottavo
« Reply #50 on: 13 Aug 2013, 06:25 pm »
I hope to own a pair of these one day ,  they look awesome and I'm sure they even sound as good as they look . Way to go Rick
bernardo
Re: Ottavo
« Reply #51 on: 13 Aug 2013, 06:42 pm »
How long will you have them available for an audition?
danny01
Re: Ottavo
« Reply #52 on: 13 Aug 2013, 07:50 pm »
Any pictures of the standard cabinets? Will they have the same shape as the speaker pictured?
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #53 on: 13 Aug 2013, 09:54 pm »
I could easily swap in the Scan-Speak mid and they would be very similar except higher sensitivity with the Ottavo.
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #54 on: 13 Aug 2013, 10:06 pm »
There's really not much information available on amp interaction with phase angles / impedance and the audible results. There is a device that can test that but you don't hear about it very often. Obviously tube amps with higher output impedances aren't a good match for lower impedance speakers and / or wide impedance variations. I have tested the Ottavo with very modest solid state amps and had great results.
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #55 on: 13 Aug 2013, 10:42 pm »
There's a local owner that can have you come listen.
Rick Craig
  • Selah Audio
Re: Ottavo
« Reply #56 on: 14 Aug 2013, 12:51 am »
No pictures but very similar in size to the Galena that I designed a few years back (same shape as the speaker pictured). For kit builders there also is a standard rectangular cabinet option and we can also build that as well if someone has a preference for a conventional shape.
rave959
Re: Ottavo
« Reply #57 on: 15 Aug 2013, 01:37 am »
These are great looking speakers!  And so are the graphs!   :thumb:
- Ian
jtwrace
    • TIPP YouTube Channel
Re: Ottavo
« Reply #58 on: 15 Aug 2013, 11:07 am »
- Ian
What graphs?
Redefy Audio
Re: Ottavo
« Reply #59 on: 15 Aug 2013, 11:58 am »
