0 Members and 1 Guest are viewing this topic. Read 10783 times.
Can't see why not...what you've sort of recreated is the original Amadeus set up, where it had conical feet and sat on an isolation platform with small squishy pucks under that. Just as musical as the present squash ball affair.
Might look to experimenting along those lines when I build my wall shelf/box for the tt, DPS and phono stage.Steve
Thanks for the idea Rob. I will try it at some point.I place my WTA on a on ikea lack tabletop on my rack. The ikea lack table top sits on isolation pads. Clearly an improvement over directly on the rack even though my system is in a basement and no worry about footfalls and such,
Hi Rob,Yes, the new Dynavector amp is a doozey. I always complained the previous HX1.2 was dry sounding. Not the new 100.
Rather than using squash balls, I'd use Sorbothane Hemisphere Bumpers.
By way of post script we used a system identical to mine bar a DVHX100 power amp instead of my more modest Densen B310. Suffice to say that I will own the DV within the next couple of months. It's a fabulous amp.
Have just ordered one myself. Auditioned it against a Naim NAP300 and a pair of Pure Audio Class A mono blocks. The Pure Audios would have won but for their inability to achieve total mastery of bass through my rather difficult speakers pushing them down to the bottom of the list.
Once I have it in place and have got used to it I will audition the L300 against the 52.
