Versalex squash ball modification
0 Members and 1 Guest are viewing this topic. Read 10762 times.
rob400
  • Versalex and Audio Note for the rest
Re: Versalex squash ball modification
« Reply #20 on: 18 Jun 2013, 07:09 pm »
Interesting that both Doak and Mick have used metal spikes in there respective arrangements. I feel my system sound benefited from eliminating all metal (and glass) from my rack. Your pics have given me an idea though.....
doak
« Reply #21 on: 19 Jun 2013, 01:39 pm »
Would never use JUST metal spikes, but in concert w/elastomer isolation it seems to be "OK."
Doak
mick wolfe
« Reply #22 on: 19 Jun 2013, 07:56 pm »
Rob,
         The WTA just sitting on a the single " spiked " butcher block didn't cut it.  That's when a second butcher block was added separated by the 4 mouse pads. Makes for a much more "isolated from the environment" presentation.....yet musically lively. I agree with Doak. Not a big fan of spikes under components.....speaker stands, yes. My initial goal was to make leveling the WTA a simple , quick procedure. Just so happened that I had several pairs of threaded spikes handy at the time. The second butcher block and mouse pads effectively take the harshness associated with spiking out of play.
rob400
« Reply #23 on: 19 Jun 2013, 09:10 pm »
Rob,
Thanks Mike.
I've just tryed a set up similar to yours but with oak veneered MDF. The bottom shelf is supported by chrome finished brass spikes into cups the top shelf with small sorbetone cones and I have refitted the squash balls onto the Versalex. Only two hours listening so far but it sounds truly excellent! I'll post the pic.
rob400
« Reply #24 on: 19 Jun 2013, 09:13 pm »
mick wolfe
« Reply #25 on: 19 Jun 2013, 09:47 pm »
Glad this is working out for you. Time will tell of course, but I think you'll find the presentation quieter/ more refined with your smaller top shelf "deadened" a bit ( as you've done ). The key is to get a quieter, more refined presentation while retaining a lifelike musical presence. Some fiddling may be required, but it sounds like you're on the right track.
doak
« Reply #26 on: 19 Jun 2013, 10:08 pm »
Precisely why I use the threaded spikes (upward pointing) under my supporting shelf.
Doak
rob400
« Reply #27 on: 20 Jun 2013, 06:40 am »
Thanks to Mick and Doak
rob400
« Reply #28 on: 22 Jun 2013, 05:47 pm »
For those following this thread I thought I'd post my conclusions. Special thanks to Mick Wolfe for his PM's.
Having tryed around six permutations of the sandwich platform my tweaking is over. I ended up with a clear preference for the one in the attached photo. Versalex without balls sat on 1/2" oak veneered MDF board with cut in half squash balls (not doubled) which sits on a 1" oak board with oak coned feet. Superb sound. Clean, open, detailed, warm and rhythmic. On a differant type of rack I can appreciate that the results might be differant but metal spikes just don't work well with my deck even two layers down. I also feel that anymore than one layer of rubber just takes away that sparkle. Just listened to Sonny Rollins Way Out West and it was amazing! Enjoy your music guys.
