Toshiba laptop
0 Members and 1 Guest are viewing this topic. Read 1818 times.
harley52
Toshiba laptop
« on: 4 Jun 2013, 05:31 pm »
Can someone tell me what to look for in a laptop to be used exclusively for music? I don't want a Mac and I'd rather stay under $600. Cheaper is better for me.
Thank you
milford3
Re: Toshiba laptop
« Reply #1 on: 4 Jun 2013, 05:56 pm »
I know this is above your price point, but its worth the extra scratch and has everything you need for a good five years.  Buying a cheap laptop will only have to be replaced soon because of the ever changing internet.
http://www.amazon.com/Sony-Series-SVE17132CXB-17-3-Inch-Laptop/dp/B00AW4O9ME/ref=sr_1_14?ie=UTF8&qid=1370368197&sr=8-14&keywords=sony+laptops
strat95
Re: Toshiba laptop
« Reply #2 on: 4 Jun 2013, 08:10 pm »
Hi, I'm curious as to what you mean by the ever changing internet causing the replacement of computer hardware such as a laptop?
mcgsxr
Re: Toshiba laptop
« Reply #3 on: 4 Jun 2013, 09:38 pm »
I recently picked up a used netbook exclusively for audio use.
I wanted 2GB RAM, a reasonably fast processor, and a 250GB drive and gigabit ethernet.  I actually store my 1.5TB of FLAC on a USB drive, but wanted a fairly large drive in the event I changed my mind.
I deleted all MS off it that I could, loaded up Logitech Media Server, and I run it wired.
Was less than $180 off Kijiji.
Russtafarian
  • Typical reaction to the music I play
Re: Toshiba laptop
« Reply #4 on: 4 Jun 2013, 10:00 pm »
I use a Win 7 HP laptop that I picked up for about $600.  It has 8G of RAM (for memory playback), 750G drive (for some music storage), Blu-ray (for ripping hi-rez FLAC from BD discs) and enough processing power to do multi-channel DSD to PCM processing via HDMI on the fly.  I run Fidelizer at bootup, open Jriver and it works great for everything I play, including DSD and multi-channel files.
Russ
Re: Toshiba laptop
« Reply #5 on: 5 Jun 2013, 12:19 am »
An example is the small screen from laptops that are useless in many current site that show a widescreen, unless your eyes are a microscope.
Iam using now a 20inches monitor and it is small in many site, it not show all the page, so Iam forced walk the bars.
Today a minimum monitor to internet it 24inches, my neighbour use a 27inches TV for PC and YouTube.
charmerci
Re: Toshiba laptop
« Reply #6 on: 6 Jun 2013, 05:48 am »
I don't see why you need anything too big or expensive.
I have the least expensive Acer 15.6" laptop from BB that I've been using for 3 years trouble free almost every day. Can't see why you would need anything more than the $350 one with a 500gb HD ($70) - especially if it's only for music. Just get dbPoweramp or like I did, JRiver and back it up with a external. Should be trouble-free.
(I have about 5K FLAC songs loaded taking up 150GB.)
whell
Re: Toshiba laptop
« Reply #7 on: 1 Jul 2013, 03:47 am »
You really don't need a heavy duty, or ultra current, laptop to set it up as a music player.  If you use Linux you can get away with even lower spec hardware and still get the job done nicely.  $300 should be enough to get you a nice laptop and an external drive for your music.  Maybe take the money you don't spend on the laptop and buy a 2nd external drive to backup your music files.
