0 Members and 1 Guest are viewing this topic. Read 13384 times.
A bunch of friends got together doing Tubes roll with Kt88 include Russian ,cheap shugunce ,black treasure ,Psvane plus a few other everybody agree the Psvane mk11 sound the best .I'm so bless with so many audiophiles in our area. lapsan
Great point Steve. Esp since I found opposite results with the new prod Tung Sol KT120s. They sound rich, creamy , musical and just effortless in my rig. So these comparos (like Steve intelligently pointed out) are alot more dependent on the overall design.
Did you try different input tubes while you tried all of these different output tubes?Thanks Lapsan!
yes,we're use 6sl7 .from,sylvania ,tung sol,GE,russian ,chinese ruby and sophia electric and we're prefer sophia eletric.
What I find interesting is that Octave V110 was designed for KT120's. It is more likely I find I like some of the more 'flavored' sound like the TS 6550 and the Ei KT90's. Those tubes get my toes tappin and my head a bobbin To me those are the most musical sounding tubes. But I also know changing the input and driver/inverter tubes can change the sound of the KT120's. That being said several people have listened to my system and I've even swapped out tubes and so far everyone loves that TS 6550 bp and gp for sounding the best.
Thanks for the above posts and shame Audiocircle does not allow you to respond to my pm! I'm curious, if you were to put the KT120 against the EAT KT88, and you could use any input tubes for either of these tubes, and your goal was to achieve as musical, but also as accurate (fine balance) a result, would the KT120's be able to even contend or are the KT120's a bit of a step below the EAT/Ei/TS6550/etc. more pricey tubes?
Are you sure this amp should not be replaced with a 2A3 or 300B type?
Thanks and myself agrees there's so much to do with amp/system/etc. dependencies.
Mind saying what other output tubes you have used against the TS KT120's?Thanks and myself agrees there's so much to do with amp/system/etc. dependencies.
