Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
The one thing I hate about vinyl....
3
4
5
0 Members and 1 Guest are viewing this topic. Read 17688 times.
plastico
Re: The one thing I hate about vinyl....
Reply #80 on:
29 Jun 2013, 07:38 pm »
With a used dryer sheet- it still has the antistactic properties in it, just let it glide over your platter while it is turning. That should cure your pesky static problem!
Cheers, Plastico
jimdgoulding
Reply #81 on:
29 Jun 2013, 09:01 pm »
Or, a soft carbon fiber brush. I use a Discwasher. too, then a soft CF brush. It is not necessary to use a washer before every play.
plastico
Reply #82 on:
29 Jun 2013, 09:34 pm »
I used both methods. I ended up using the my carbon fiber brush on the platter . From the edge to the spindle, it grounds out on the spindle. And it just cleans up the clutter around your table.
Cheers, Plastico
WireNut
Reply #83 on:
30 Jun 2013, 01:49 am »
Is not owning a microscope
3
4
5
The Vinyl Circle
woodsyi
