Pass through mode on B135 amp
0 Members and 1 Guest are viewing this topic. Read 1175 times.
Kencohen
« on: 1 Jun 2013, 07:16 pm »
Can anyone explain what I need to do to engage pass through mode on my B135 amp? The explanation in the manual about using a "null modem cable" doesn't help, as I don't know where to get one or how to use it. Thanks in advance.
srb
Re: Pass through mode on B135 amp
« Reply #1 on: 1 Jun 2013, 08:29 pm »
Sending the code via RS232 serial port is only necessary for those that don't have a remote control.  If you have a Bryston remote control you just press the Code button followed by 245 and whatever input is currently selected will be programmed as a unity gain "bypass" input.
If you don't have a remote control then you will need a computer with a serial port (or a USB > Serial Port adapter), a fairly standard serial "null modem" cable available at most computer and electronic shops, and a terminal program to send the 245 code from (Windows XP has the Hyperterminal program, but it was removed from Windows Vista on).
Do you have a remote control?
mike_hifi
« Reply #2 on: 3 Jun 2013, 10:01 am »
If the operating software for the B135 is the same as the B100, do not waste your time going down the RS-232 path. I have just tried this to no avail on a recently purchased B100 and have had this confirmed by Bryston service it is not possible to activate passthrough on the B100 this way.
I am currently trying to organise the loan of a BR remote. I will do my utmost to load the passthrough code up to Logitech once I have this, so that if you get one of their remotes you should be able to use that.
Mike
RSB
« Reply #3 on: 4 Jun 2013, 03:05 am »
OK, I'm having a Duh moment.  The B-100 has a pass-through?  I own one and never knew it.  How does it work?
Randy
srb
« Reply #4 on: 4 Jun 2013, 03:11 am »
From my post two posts above:
"If you have a Bryston remote control you just press the Code button followed by 245 and whatever input is currently selected will be programmed as a unity gain "bypass" input."
Entering the code again will toggle it back to a normal input.
RSB
« Reply #5 on: 4 Jun 2013, 07:25 pm »
srb -
Thanks!  I'll try it!
Randy
