Looking for: cheap Toslink DAC set-up to connect plasma TV to A/V system
0 Members and 1 Guest are viewing this topic. Read 5435 times.
dburna
I have a Panasonic plasma with a Toslink audio out connection.  I rarely watch TV, but when I do, listening to the TV through the crap-ass monitor speakers bothers me.  As I have an A/V system down in the basement (for watching movies, where the sound does matter to me, I have an easy way to upgrade the sound of my (basic) cable.  All I need is:
1. A Toslink DAC that is cheap but listenable (or better).  Doesn't have to be the end-all-&-be-all.
2. A Toslink cable to go with it.  Also looking for something with decent performance, (greater) emphasis on the "cheap" part.
In the end, I want better sound that through the TV speakers, but pretty much anything would be an improvement.  Thanks muchly for your recommendations and sourcing pointers.
-dB
P.S. I looked through this circle but didn't find any similar requests.  If I missed something, please let me know if this has been answered already.
gwing
At Amazon search for "spdif to rca" and there were a number of options that come up, including a 6 ft Amazon Basics spdif cable for < $6.
I've used the FiiO D3 and the C2G / Cables to Go 40019 converters, neither seem to do anything objectionable to the sound coming from my TVs for < $30 each.
Phil A
timind
  • permanent vacation
What do u consider cheap?
srb
This has been talked about some, I know I've posted some thoughts in a few topics, but your particular equipment setup would be of interest to know what to possibly recommend.
If your basic cable is Standard Definition analog, then the sound would be 2 channel stereo that could be decoded by any standard external DAC with a Toslink input.
If your cable is High Definition digital (or ATSC over-the-air digital), then the majority of programs will carry Dolby Digital 5.1 multichannel sound, which will require a DAC that can decode Dolby Digital.  Any surround receiver or processor can decode it, but there are very few stand-alone Dolby Digital DACs.
The digital audio output from some TVs, including my Panasonic plasma (and many Panasonic plasmas) does not have a menu option to select 2 channel PCM stereo vs multichannel output.  If your particular TV does have that ability, then any external stereo DAC would work.  If you are using a cable box, they usually have a menu setting to set the digital audio output to 2 channel PCM, but if you just have basic cable, I assume you are probably going directly into your TV with the cable?
I'm also assuming that your A/V system is either a stereo-only receiver or integrated amplifier, hence the request for an external DAC.
The FiiO mentioned above is one of a very few available digital multichannel DACs that would work.  Another is the Gefen GTV-DD-2AA, but the Fiio decodes Dolby Digital and DTS, whereas the Gefen is Dolby Digital only.  Not sure if there is any DTS on cable, but if the cost is similar might as well have the capability.  There are also some older stand-alone Dolby Digital/DTS decoders about the size of a slimline DVD player that were available years ago from manufacturers like Panasonic, and those can be sometimes be found on eBay and Craigslist for next to nothing.
Russtafarian
  • Typical reaction to the music I play
That FIIO is a cool device.  I may get one for my bedroom system.  Parts Express link:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=230-134
Another option if there is no system near the TV is a soundbar with a Dolby Digital optical input.  It's no replacement for a home theater rig but it's compact and sounds much better than TV speakers. I've had good success with this one.
http://www.accessories4less.com/make-a-store/item/BOSTVEEM30B/BOSTON-ACOUSTICS-TVee-30-150W-2.1ch-Soundbar-w/7in-Wireless-Sub/1.html
Russ
