Newbie bass management High Pass Filter and EQ
0 Members and 1 Guest are viewing this topic. Read 1469 times.
danny01
« on: 12 May 2013, 11:05 am »
Recently I switched from a 5.1 to 2.2 system, and I am reading quite a bit about bass management without using an HT pre pro. I currently have a Parasound 2100 and Emotiva XDA-2 dac. Being that all of my sources are digital and the XDA-2 handles the switching, the only thing I use the Parasound for is the high pass filter, sub crossover, and volume control and it seems like a waste. I am thinking about eliminating the Parasound. The XDA-2 supposedly has a "lossless digitally controlled analog volume control" that controls both the XLR and RCA analog outputs levels at the same time. Since my speakers (sealed Selah Prestigio) have a -3dB @ 75hz, I am thinking about putting a HSU high pass filter between the DAC and main amps via RCA, and a DEQ2496 between the DAC and subwoofers' amps via XLR. I would use the DEQ2496 to roll off the highs to the subs (dual Epik Empires) and EQ it. I am aware that the DEQ2496 will be doing AD/DA conversion to EQ, but I am not concerned about this as the output will be going to just the subs.
My goal is to have a HPF and Sub EQ with the least amount of sound degradation. Would there be any reason not to go this route? Would I lose sound quality in using the HSU and Behringer units as opposed to the Parasound? Does anyone have experience with the HSU unit? How will the HSU HPF compare to the one in the Parasound? I am open to other suggestions as long as I won't have to sell a kidney to implement it.
medium jim
Re: Newbie bass management High Pass Filter and EQ
« Reply #1 on: 12 May 2013, 01:51 pm »
Start here:
http://www.audiocircle.com/index.php?topic=106831.0
I'm sure that someone will jump in.
Jim
ricardojoa
« Reply #2 on: 28 May 2013, 07:47 am »
You can run try to run your prestigio full range and cross your sub at around 80-50 hz, play with your phase and see how it sound. I have selah tempesta and cross them at 50hz, and im running full range(sealed with port pluged) roll of at 67hz-3db.
rodge827
« Reply #3 on: 28 May 2013, 10:58 am »
I have a 2.2 system and use the Dspeaker Antimode Dual Core 2.0.
You can read a lot about it here:
http://www.audiocircle.com/index.php?topic=110377.0
Enjoy
danny01
« Reply #4 on: 11 Jun 2013, 01:59 pm »
Thanks guys. I looked into the Antimode, MiniDsp, Behringers and Marchands. I went with a minidsp for the subs. Still on the fence about keeping the Parasound as my high pass filter or going with a dedicated analog high pass filter. The channel imbalance on the Parasound at lower volumes is very noticeable and quite annoying..
