Bargain Stereo Pre-amp
0 Members and 1 Guest are viewing this topic. Read 2945 times.
gongos
« on: 13 Jul 2004, 12:01 am »
I'm looking to find a good, but cheap, 2 chanel pre-amp on the used market. Any suggestions?
RooX
« Reply #1 on: 13 Jul 2004, 12:21 am »
how cheap? like 500.00 cheap or like 100.00 cheap?
loads of great options
vpolineni
« Reply #2 on: 13 Jul 2004, 12:29 am »
IRD purist used would be a great value..  for something around 150 dollars the luminous audio axiom preamp has received rave reviews.
Mad DOg
« Reply #3 on: 13 Jul 2004, 12:44 am »
you might have to define what "good" and "cheap" mean for you...
gongos
« Reply #4 on: 13 Jul 2004, 01:52 am »
I'm looking in the $100-$200 range. Good=sounds good. I own a tube-modded 999es.
gongos
« Reply #5 on: 13 Jul 2004, 01:54 am »
Is IRD short for something?
  • Speakers....What Speakers ?
« Reply #6 on: 13 Jul 2004, 02:18 am »
Quote from: gongos
 http://www.audiocircle.com/index.php?board=33
gongos
« Reply #7 on: 13 Jul 2004, 07:10 am »
Thanks for the link.
JoshK
« Reply #8 on: 13 Jul 2004, 02:00 pm »
Gongos,
Are you handy?  I just bought all the parts to build a 5687 (same tube as Dan Wright uses in the Modded 999) based preamp.  Total parts are well under $200.   It is suppose to be a very linear and dynamic tube based preamp.   I'll let you know how it sounds when it is complete.  It looks fairly straight forward to build.
More details here
Passive Chappy
« Reply #9 on: 13 Jul 2004, 06:15 pm »
Look for a used Creek OBH12.  A great remote controlled passive preamp.
randytsuch
« Reply #10 on: 13 Jul 2004, 06:47 pm »
Quote from: JoshK
Gongos,
More details here
Just be carefull with tubes.  They run at high voltage.  I always put bleed resistors on the high voltage caps, otherwise the power just stays stored in the cap.  Could give a REALLY nasty shock.
Randy
JoshK
« Reply #11 on: 13 Jul 2004, 08:02 pm »
Yeah I have read that before, actually in this tutorial that Yeo writes on how to build this preamp he states that more than once and at the beginning.
ABEX
« Reply #12 on: 13 Jul 2004, 08:22 pm »
I'm looking for something similar. I would like a Pre with a Phonstage for under $200 to hook up to a 5ch. B&K amp.
Any suggestions? Maybe a receiver with Pre Outs?
TIA
