Integrated Amp
0 Members and 1 Guest are viewing this topic. Read 2090 times.
mmurt
Integrated Amp
« on: 9 May 2013, 11:25 pm »
Ever any thought on a no holds barred integrated?  Maybe a Fet Valve with phono, remote and dac ...   May make the WAF a little easier to take.  Chassis size would not be an issue unless it was huge.
mca
Re: Integrated Amp
« Reply #1 on: 10 May 2013, 12:15 am »
Throw in a home theater bypass and I would look into buying one :D
iamjaymo
Re: Integrated Amp
« Reply #2 on: 10 May 2013, 08:53 pm »
They do make one don't they??? Based on Synergy and EC pre?
mark funk
Re: Integrated Amp
« Reply #3 on: 10 May 2013, 09:01 pm »
Yes,
http://www.avahifi.com/index.php?option=com_content&view=article&id=267&Itemid=229
        :smoke:
mca
Re: Integrated Amp
« Reply #4 on: 11 May 2013, 12:03 am »
Correct, they do have an integrated, but not based on the Fet valve amp and no built in DAC.
trebejo
Re: Integrated Amp
« Reply #5 on: 14 May 2013, 06:34 pm »
The solid state integrated with a built-in DAC stage is a great problem-solver. I think solid-state is preferable to tubes in this configuration because it's a better ergonomic fit--since you're going for convenience, maximize that.
If the tube option sounded waaay better then that would be a tough way to go, but I'm sure AVA is taking care of that divergence.
avahifi
    • http://www.avahifi.com
Re: Integrated Amp
« Reply #6 on: 14 May 2013, 10:13 pm »
We can build a Vision DAC and Insight+ SL or EC preamplifier combination with excellent results but not a combination of a Vision DAC and Synergy Integrated amplifier.
The Synergy Integrated amplifier with three large PC cards and three internal heat sinks plus a fourth raw power supply circuit board and a huge toroid power transformer just does not have any real estate left over for our DAC circuits.
Note that the Vision DAC/Preamp and the Synergy Compact 240 power amplifier will stack (amp on top) and the pair match and take up the same space as one of our large chassis amplifiers, 7" high x 17" wide.  A really nice pair.  Buy both at the same time and save 10% and free shipping.
Frank Van Alstine
