0 Members and 1 Guest are viewing this topic. Read 11475 times.
The Pioneer is 30 watts at 8 ohms and your Fostex drivers are rated at 50 watts music power (whatever that means).
Thanks Richidoo. 50 watt is too much(not needed) for my 15W rated FR speakers..always carry a risk of burning them off by someone full throttling the gain too.
How can a low power rated amp can destroy speaker by clipping?
How about the famous NAD 3020 integrated from the 1980's (20 watts at 8 ohms)? That model sold like hotcakes and put NAD on the map.
Hey! With SS amp, you are more likely to burn your speaker out with lower wattage amp than with higher one because you are more likely to clip the lower wattage SS amp than higher wattage one. And when that happen you'll get cooked voice coil(s) Of course with tube, the amp will just run out of steam and no harm done... well as long as the amp was well designed at the first place. Hmmm.... it will make it easier for us if we know what is your budget for this? Is tube really out of a question here? Take care,Buddy
There is a Dayens Ampino 25W SS integrated for sale on AC.http://www.audiocircle.com/index.php?topic=114073.msg1189697#msg1189697It got great reviews including by Srajan Ebaen and the price seems reasonable.
I was under the impression that a higher power rated amp (like 30-45W) can burn the 15W rated coils in FF125WK if someone turns up the volume accidently. But it seems like that is not the case. How can a low power rated amp can destroy speaker by clipping.Please give me something to read.I guess I need to read more?
