Error 5 on BDP2
0 Members and 1 Guest are viewing this topic. Read 1906 times.
Blueshirt1
Error 5 on BDP2
« on: 20 Apr 2013, 12:25 pm »
Hi, just got my BDP 2 a few weeks ago. I normally leave it on for the lost part but have noticed whenever I turn it off and turn it back on later on I get a error 5. After I shut it off again and turn it back on the error goes away.
Anyone have a clue as to what this error means?
thx
  • The Demo is Everything!
    • http://www.bryston.com
Re: Error 5 on BDP2
« Reply #1 on: 20 Apr 2013, 12:28 pm »
thx
Error 5 means the power is a touch too high in voltage. - May be a turn on surge.  Do you have a power conditioner?
james
Blueshirt1
Re: Error 5 on BDP2
« Reply #2 on: 22 Apr 2013, 12:02 pm »
Re: Error 5 on BDP2
« Reply #3 on: 22 Apr 2013, 12:09 pm »
Hi James,
I have an filter.
http://www.lampizator.eu/NEWDAC/Lampizator/NEW!_SILK_AC_filter.html
Ok please try plugging the BDP directly into the wall rather than through the switcher.
james
Blueshirt1
Re: Error 5 on BDP2
« Reply #4 on: 22 Apr 2013, 12:29 pm »
Is there an issue with the switcher?
Re: Error 5 on BDP2
« Reply #5 on: 22 Apr 2013, 01:04 pm »
Not sure but I want to eliminate that possibility.
james
Blueshirt1
Re: Error 5 on BDP2
« Reply #6 on: 22 Apr 2013, 08:19 pm »
Moved it to the wall and so far no error message. I will try it a few more times.
What are the specs that I need to mention to the manufacture of the filter? it should work through there.
Re: Error 5 on BDP2
« Reply #7 on: 22 Apr 2013, 11:26 pm »
i just find some of these external products seem to create 'issues'
james
Blueshirt1
Re: Error 5 on BDP2
« Reply #8 on: 23 Apr 2013, 01:06 pm »
James,
It is still happening plugged into the wall. Now it wont even turn on.
Re: Error 5 on BDP2
« Reply #9 on: 23 Apr 2013, 02:03 pm »
James,
Ok please contact Mike Pickett at bryston and we will get it sorted.
[email protected]
james
