Tubes for the sake of tubes.
0 Members and 1 Guest are viewing this topic. Read 1612 times.
fredgarvin
« on: 17 Apr 2013, 03:32 pm »
For all of you that can't resist the cool, or romantic glow of tubes on your rack or desktop, here is a fine tube product that will both allow you to use that tiny Tripath amp you have guiltily been coveting and give you that warm glow that has you spellbound:
DIY Nixie Tube Thermometer Kit
 The device displays Fahrenheit, Celsius, humidity and Kelvin and even has a motion sensor to switch the display when it senses movement.
http://www.thinkgeek.com/product/f352/
Re: Tubes for the sake of tubes.
« Reply #1 on: 17 Apr 2013, 04:37 pm »
Would be nice a nixie with letters to gift wife with her name.
JohnR
« Reply #2 on: 17 Apr 2013, 06:50 pm »
714F? Shouldn't that be 451?
It would be a lot cheaper to just put in whatever tubes and connect the filaments to a small transformer. Believe it or not, I was thinking about doing just that today....
Rclark
« Reply #3 on: 17 Apr 2013, 06:59 pm »
We can probably assume that since these are actual tubes, the display is more a record of the previous room temperature as with this on it should be constantly rising  :lol:
Zyca
    • Acoustic Fun Web Store!
« Reply #4 on: 19 Apr 2013, 03:20 am »
Hello John, sorry for the off topic post to your discussions, your private message box is full.  I need to send you a private message.
On a side note, nixie tube have been getting rather expensive lately, all the good looking ones are either gone or costing an arm and a leg.  I remember seeing them offered as kits about 25 years ago when I was in Taiwan, and 5 years ago they became all the rage again.  With simple kits that takes AC frequency to run the clock to uber precise GPS calibrated time.
