Bryston BDP-1 building playlists?
0 Members and 1 Guest are viewing this topic. Read 948 times.
BrystonNut
  • Bryston, there is no substitute!
« on: 12 Apr 2013, 03:17 pm »
Hi,
Using the latest firmware build, question...how do I remove a track from a playlist or change the order?
Anyone? :deadhorse:
Love the smileys on this site :D
drummermitchell
Re: Bryston BDP-1 building playlists?
« Reply #1 on: 12 Apr 2013, 03:49 pm »
Very good Question.
Marius
« Reply #2 on: 12 Apr 2013, 04:37 pm »
delete:
select playlist, then click edit, and delete tracks from the playlist...
moving not possible from within Max at the moment other than rebuilding it from scratch in the right order... Chris is working on this we all hope.
In Mpad, you might be able to do it all, seems an overall more fluid experience.
cheers!
Marius
