AA batteries for Bugle kit?
0 Members and 1 Guest are viewing this topic. Read 1761 times.
TheTurntableFactory
« on: 30 Mar 2013, 12:02 am »
I'm archiving albums that never will make it to CD (or that the CD versions are "remastered" and no longer match the original LP mix), so I want the noise floor to be as low as possible.
Can I substitute the each 9v battery with 6 AA batteries? Will this burn anything out or degrade the sound?
I intend to use the Bugle Power supply for casual listening.
hagtech
    • http://www.hagtech.com
Re: AA batteries for Bugle kit?
« Reply #1 on: 30 Mar 2013, 03:55 am »
That is perfectly fine.  Just be careful not to wire in the negative battery pack backwards (the "+" is ground).
jh
