Mini pc
0 Members and 1 Guest are viewing this topic. Read 1757 times.
sts9fan
chip
Re: Mini pc
« Reply #1 on: 29 Mar 2013, 06:43 pm »
What are you going to use it for? Just playback of audio with foobar/jr river?
sts9fan
Re: Mini pc
« Reply #2 on: 29 Mar 2013, 06:48 pm »
Correct. Strictly audio. Including Spotify and Internet radio.
chip
Re: Mini pc
« Reply #3 on: 29 Mar 2013, 06:52 pm »
That would work.
Another option might be this http://www.newegg.com/Product/Product.aspx?Item=N82E16856119080 just add memory & OS. No wireless on this device though.
srb
Re: Mini pc
« Reply #4 on: 29 Mar 2013, 10:23 pm »
The 20GB SSD included in the linked Intel package is probably a bit small for a Windows installation.  The OS would fit, but wouldn't have much room for paging file, hibernation file, updates or defragmentation.  I would look for a package that either includes a 32GB to 64GB SSD, or select one without SSD and add it separately.
newzooreview
Re: Mini pc
« Reply #5 on: 29 Mar 2013, 11:16 pm »
What are your thoughts on this?
http://m.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7779666&Sku=B69-9020
Unless you're biased against Macs, I would buy a used Mac Mini off of ebay for essentially the same price. It's well known to be a great music server and there is a lot of support for upgrading its performance. A lot of businesses participating on AudioCircle prefer and support the MacMini: PI Audio (power cables, battery conversion) and dB Audio from direct experience. Audirvana Plus is a terrific player as well.
It's hard to evaluate a no-name pc on Tiger Direct. If you do want a Windows based system I would look into one of the music server builds at Computer Audiophile. They seems to have seriously evaluated the various options in building a server for Windows.
From my own experience, changes to the computer feeding the DAC are very audible, so attention to that part of the system is well worth it.
Good luck, and happy listening.  :thumb:
sts9fan
Re: Mini pc
« Reply #6 on: 29 Mar 2013, 11:27 pm »
I am not against macs per say but I see no reason or benefit to go that route.
I feel there is less value.
Doublej
Re: Mini pc
« Reply #7 on: 30 Mar 2013, 12:03 am »
Seems like once you add a Windows O/S and a larger hard drive, price wise you are in spitting distance of a Mac mini. Then becomes a matter of personal preference.
I don't understand why mini pcs are not as cheap as bigger desktops but given that they aren't I would go with a $300-$400 laptop.
sts9fan
Re: Mini pc
« Reply #8 on: 30 Mar 2013, 01:01 am »
I already have a Synology NAS so storage is moot.
That computer audiophile CAPS Lagoon seems nice but I don't know if I need silent.
I could mount the computer in the basement below my listening room.
Hmmmmmmm.
