0 Members and 1 Guest are viewing this topic. Read 22899 times.
I have mine on the short wall (12.5 feet wide) too. I spent a long time trying them in various positions. They are not as easy to dial in as the VR-22, but they do so much more. Currently mine are 9" from the back wall, and 28" to the edge from side wall (open on the other side, but there are some obstructive "treatments") I think they sound terrific, but that's just me.
Interesting, having them that far out from the side wall in a 12.5' room means you have the speakers fairly close together (a bit over 6' center-to-center if my math is correct). How close is your listening position to the speakers? I'm curious to know what it does to your soundstage. I actually can't move my speakers that close together because I've got a salamander cabinet between them. So I'm battling not only room corners but the corner between front wall and cabinet as well. But, I'm quite happy and surprised by how much the bass tightened up by pushing the speakers to just 3" from the front wall (from the 8" I previously had them). Seems counter-intuitive, but damned if it doesn't work well.
I realize this is a somewhat old thread, but the topic is all about VR-35 speaker placement so here goes...I've been the proud owner of the VR-35s now for 2 years! How time flies.When I first got them, they were on the long wall in my 12'x24' living room. They sounded great there placed about 8" from the front wall and far, far from the side walls. Bass was tight, deep and tuneful and the soundstage was to die for extending well beyond speaker boundaries. But... then we started a remodeling job and I decided to move them into a smaller room and integrate them into my home theater setup. What that meant was moving them from the long wall to the short 12' wall in a 12'x18' room. Alas, that didn't go so well and had me scratching my head. The bass became a bit overwhelming and less controlled and soundstage collapsed. My instinct was to pull the speakers closer together to get them away from the corners. I also pulled them more out into the room trying to tame the bass (even though VSA says they are at their best when essentially against the front wall). Well, that sure didn't work. If anything, the more I pulled them out, the less controlled the bass became with less focus in the soundstage. So with more time over the holidays to play with it, I took a different approach. I moved them to within 3" of the front wall and 14" from side wall (from speaker edge) which placed them just a bit over 8' apart. Damn if that didn't make a big difference! Bass tightened up dramatically with far better slam. The soundstage and image focus was also much improved. Even just pulling them out to 8" from the front wall as I had them in the other room had a noticeable negative effect on bass and slam. Now that surprised me. I need to learn to listen to Albert when he says they are best when against the wall. I'll continue to tweak positioning a bit but now in much smaller increments. And I might just need to break down and consider some room treatments. Anyone else out there with similar VR-22/VR-33/VR-35 speaker placement stories? It does seem that these speakers make most everything I thought I knew about speaker placement somewhat obsolete. Mike
I've still got them just 3" from the front wall, but continue to tweak lateral placement trying to balance tonal balance and soundstage. Pulling them much further away from the front wall definitely seems to increase bass boominess. I currently have them 16" from side wall to speaker edge. gme109 - I'll be very interested to hear your results. I'm sure every room is different, but then, so are these speakers.
gme,If you read my VR-22 article on PF, I think you will note that I also, couldn't believe that these speaker designs throw in the face of convention. Thinking bass could not possibly get tighter by moving them back. Still, I struggled with finding the best location for the 35s and while I now believe I am very close, there is more tweaking to be done. Also, because I use so many different amps, I have found that each throws a little different soundstage. That said, based upon your findings, I think I will spread mine farther apart again and see if I can tame the corner. While I really like the set up now, I think I may be able to improve them even more with a 4-6" move laterally to that 20"-22" off the wall distance. I will report my findings!Cheers and happy listening!g
All, Better late than never perhaps... I had rotator cuff surgery a little over 8 weeks ago, so I have not been able to change the position of my speakers. Tonight (with a bit of help), I moved them back to 7.5" and move the one in the corner to 22" to the edge. Also, I have thrown my REL sub back in the mix too. I don't have the sub quite dialed in yet, but I think I have improved the sound even more. My room is roughly 12x16, but kinda complicated with the added volume around it...even so, the bass is not at all overwhelming. But, if I move around the room, there are places where it is kind of woolly.Big Swede, I didn't notice your post before regarding the 22s, I have not heard the 33s, only the 35s. IMO, they both have a similar approach to sound, but the 22s are much easier to dial in and are not as fussy about amplification. I gave the 22s my only PF year-end award. They are just an outstanding value. The 35s are much more sophisticated and in turn, take a bit more work to sound their very best. I am still finding new ways to improve them. I don't have a perfect room either, but I can overcome some of the issues with a little work. I will be getting a pair of 180w KT120 monos to try very soon and I expect they may be really great with the 35s. It should be interesting to find out what they can do with that much tube power.It should be fun! I will report...
