0 Members and 1 Guest are viewing this topic. Read 10605 times.
This is the second thread regarding this problem. Over the several pages of both threads you've gotten some really good advice that has not worked for you. Maybe it's time to sell everything and start over from scratch? Or at least replace the integrated?
but this is exactly what I had and it was very bad. the SUT's are typically 26db, which puts me right back to what I have now at ~65db.so it sounds like I am better off with a higher output MC (my current is .25mv) and then a phono pre with less gain? I thought if I dropped the gain significantly with a LOMC it's going to affect the performance of the cart?
Zesto Andros phono stage (55db and 65db)Line Magnetic 218IA integratedI also tried K&K Maxxed-Out w/A23 SUT (64db, 200ohms output) and Manley Chinook with and without A23 SUT (71db/60db, I think 50ohms output?) phono stages, same issue.the Leben phono stage with A23 SUT (49db) is the only one that's quiet so far.
What was the max listening volume with the CD player? If it is much lower, we know the gain is the only thing to be overly concerned about.
I hooked up the Oppo and my max listening level is pretty much exactly the same as analog, right about 9 o'clock.
Did your BAT amp have as much gain as the LineMagnetic? I don't remember......I imagine the LineMagnetic has at least 30dB of gain, probably more. Add that to 60dB of phono gain and you may have 90 to 100 dB of gain. Thats more gain than a microphone preamp uses in a recording studio. That's just a lot of gain. The odds are against you.
That right there shows me that the extra noise is comming from the phono set up. Get a moving magnet and a Leben and you will be happy.
I've had MM and don't feel it can compete with MC, especially MC with a SUT involved. I would much rather deal with the noise than go to an inferior (to me) cart setup. now we are back again at the phono pre being the problem, but why would it be silent in other systems?doesn't a typical amp/pre-amp setup have the same amount of gain that my integrated has? how is everyone else pulling this off with acceptable noise levels?
You're one post ahead of me.Which MM carts have you tried? and with which pre?This is getting long..... Not sure if I can hang here for much longer, so I may be delayed in my next reply.I think your expectations need a checkup..... But I say that with honest and kind feelings.
Check this out. I have never heard a LOMC set up that is dead quiet. The quietest and best I have heard involved a very expensive SUT into a MM phono, and there was hum present instead of noise. So, if you have heard a dead quiet LOMC set up, you should be explaining to us how you achieved it.
I don't know.Check this out. I have never heard a LOMC set up that is dead quiet. The quietest and best I have heard involved a very expensive SUT into a MM phono, and there was hum present instead of noise. So, if you have heard a dead quiet LOMC set up, you should be explaining to us how you achieved it.
I'm going to guess they are pretty efficient speakers so visible moving in and out is associated with low frequency. The signal to noise ratio in the amplifier may just not be nearly as good as the phono's, but the Oppo could be closer. You've got lower gain and SNR in the Oppo so it won't be taxing the preamp stage of the amplifier.
