0 Members and 1 Guest are viewing this topic. Read 10611 times.
I'm relaying the info here that was given to me when I spoke on the phone to the designer of my phono pre. he's the guy who designed and built a phono stage that has received nothing but praise from every professional reviewer and end user. unfortunately because I am not as technical as you I cannot relay everything he said, but he did say it was because of the high input sensitivity of my amp.
Hey Vortrex,If your input stage gain is much higher than it needs to be to amplify the phono input, there's every chance that the noise that you hear regardless whether the input is shorted or driven with a phono stage is coming directly from the preamp stage in the integrated amp. If you reduce the gain of that stage, its self-induced noise at the input will drop along with the gain reduction. The best course of action is to find the part of the circuit that amplifies the input, maybe an op-amp or transistor/tube amp, and adjust the gain to the level you think it needs to be. In most cases, one resistor for each channel would be all you'd need.I know a tech who can handle that for you if you don't have one local.
I understand digital will likely be more quiet, but I've had plenty of analog rigs more quiet than what I have now. my first $400 phono pre was more quiet than this. I have a hard time believing the Zesto is this noisy by nature, because I think it would be very hard to sell them. I've stuck with it because despite the background noise it is one incredible sounding phono stage. also, with 35db of gain for my integrated that does not seem that out of the ordinary, right? guess I am still trying to understand what specific thing is it with my system that others are not experiencing in theirs. I do have plenty of knob left, too much, 9 o'clock is my max listening level.
If you're plugging in the CD and its dead quiet, but noisy with the phono pre, then the phono pre is the source of the noise.
I recently auditioned both the Chinook and Zesto and they were dead quiet with the dealers setup. He really cranked the volume (without a record on) and the background noise was barely audible.Have you tried swapping out a different pre-amp/integrated? Perhaps you have a friend that would let you borrow one? That would at least narrow down the possibilities.
You got better results with the Leben so I suggest you head back down toward that path if you want less noise. If you absolutely have to have a LOMC cartridge then you need a phono pre with 35-40 dB gain and a step up transformer. A good tranny is not cheap and there are placement issues to consider, as you well know.
dude, move along. you are clearly nuts and the writings on your site and ALL your previous posts here reflect that.
