0 Members and 1 Guest are viewing this topic. Read 8886 times.
What, no love for Stevenson?Seriously, I thought all the older Japanese tables were set up to use Stevenson, one of the reasons they can't get to Lofgren B. I used Stevenson to align an old Pioneer gift table that I'm restoring, the cart lines up right in the middle of the headshell.
So, if Stevenson's alignment has so much distortion, why did these early Japanese tables use it?I have an early Japanese table (JVC ql-a7, S arm) and notice IGD more so than outer or middle grove distortions. Not quite sure what alignment I'm using right now (I'll have to check) but it was aligned pretty accurately.Seems like I should be applying an alignment closer to Stevenson's and adjusting anti skate for this region of the lp.Also, is this true? If I align to two points on a given alignment, I do not have to be concerned with overhang.
If you change your alignment your overhang changes with it. Right, so am I done with overhang if alignment is set to the protractor I chose?How do you know the JVC was aligned accurately?How do you know yours is As accurately as I can get it with correctly printed VE protractors. visually inspected for twist. Would love to get a mirrored one some day.Stevenson minimizes alignment error at the lead out groove where the inner null for that alignment is located. Alignment error is greatest at record center where Lofgren is best, that's why Lofgren has lowest total error. Baerwald has the most even sound or lowest average error across the entire record. Yep, I understand that and the concept of lp's using up all available space (classical). I was wondering why TT were manufactured to a highter distorted alignment in the first place.I think something other than alignment/AS is causing your IGD, although they might be complicating matters. Not enough info to go on, I think the situation will require some hands-on solutions.I figured that but I'm not done learning and experimenting yet. I don't believe I have tried the Stevenson alignment yet as I figured lowest ave makes sense to me. Thanks Neo!!neo
Many Japanese tables actually can reach a Lofgren B. Sony PS-X5/X7 series can get to this alignment. My X7 is set-up this way and Frank's X5 is.To be truthful, I'm not sure back then if they knew about all the alignments. They didn't have the internet to find out stuff at the stroke of a key. Many of those tables also had short spindle to tonearm pivot distances, like the Sony is only 200mm. Perhaps back then, they were also trying to keep the footprint of the table as small as possible too.I think the golden rule of engineering applies here: All designs are compromises.Wayner
Wayner I have yet to sign up for AK, but in the meantime I tried seb's Technics alignment for a 215mm arm, but could not reach the arc due to running out of slot length in the stock headshell. Should I expect to require to buy a new/longer headshell to run your alignment? I believe a store on the other side of town carries longer headshells.Thanks,Ray
