0 Members and 1 Guest are viewing this topic. Read 37533 times.
I'm always good thanks. Part of me wants to let you try my amps but I think your bias dial might be stuck.
Re. OTL driving GedLee Abbey: negative search for Abbey impedance graph. Please post if anyone has such.
A Google image search on "gedlee abbey impedance" yields:http://www.audiocircle.com/index.php?topic=87209.msg852984#msg852984
I'm thinking of trying a 30 wpc Tripath amp. Currently I run a 100 wpc Class AB SS amp into my 6 ohm, 86-87 db sensitivity speakers, which are hipassed internally at 200 Hz, so the amp only has to drive the frequencies above that. I'm in a 12x11x9 ft room sitting about 8.5' from the speakers. I like it loud when I can, but I really don't know what decibel level that translates to at the LP (is there a decibel meter iPhone app or do you have to buy a special tool)? I listen to modern jazz and various and sundry pop/rock/electronic/soul/funk genres, most recorded in the last 15 years.Anyway, any opinions about whether I'll have enough power at 30 wpc?
While your speakers may get high passed at 200Hz, the amp is still producing the full spectrum. Unless you high pass the signal to the amp, you gain nothing, and in fact, will have less available output moving down to the 30W amp.Amps are voltage sources, and when the voltage reaches the supply rail level, they will "clip." It doesn't matter that they aren't sending any power to the load. In fact, an amp can clip when delivering ZERO watts. Active setups work best when the crossover is set up between the source and the amp inputs. Breaking up the music signal into a series of bands allows a smaller amp to deliver closer to its max rating without clipping.For example, if a high quality recording has a 10:1 peak to average ratio (crest factor), that means for 1W of music power, the instantaneous power requirement is 10W. If you break up the spectrum into 3 pieces, you can reduce that crest fact to 3.33:1. Now, instead of needing a 10W peak output to deliver 1W RMS, you only need a 3.33W peak output to deliver 1W RMS. But that has to be done before the amp input, not between the amp and speakers.
Which Tripath were you thinking of? You're welcome to try my Virtue if you want. Should blend well with your speakers as they are high passed. It's about 55 watts at 8ohm.
Are those numbers that you spoke of accurate - as in the 1:10 continuous to peak power ratio- , and if so wouldn't that mean that an amp should be capable of delivering at least 100 wpc peak (plus headroom, I assume)? Is the amp likely being pushed to 10 watts of continuous power in my situation?
My current amp is a bit noisy
The Peachtree?
I've got a reasonably powered amp (225 wpc) and a 3,000 cf family room open at back to a 1,000 cf kitchen. I'm considering new bookshelf speakers. What minimum speaker efficiency should I be considering? I previously saw a formula I could probably use to reframe the calculation, but I haven't been successful relocating it.
