0 Members and 1 Guest are viewing this topic. Read 37526 times.
Yep. I'm convinced that "audiophile" is really an acronym for "technically illiterate, not-very-critical listener, highly gullible" in some obscure language.The problem is that the prevalence of such types starts to either crowd out the good guys. So people buy fetish amps and run boutique wires on special little audiophool wire holders, but drive loudspeakers with midrange mushroom polar patterns and midbass peaks like bad 1980s car stereos.
I don't put much stock in any as I prefer my ears over science.
Hi Jim,That is both a contradiction and false.The scientific method for determining sound preference is by ears. That is, by definition, blind listening. Ears...only.You do no such thing, as I have explained previously (Unless you are now telling us your equipment selection is based on controlled (ears) listening only?).The whole "tube vs SS" watts is utter nonsense. A watt is a watt. Dynamic headroom is dynamic headroom. Etc, etc.Unless this lab is a "meth" variety, the science is quite simple. cheers,AJ
I must admit, from my school days, the formula for a watt does not change between tubes and transistors. Mike made an excellent point earlier about the rail voltages on a tube amp as opposed to solid state amps.
Jim, several percent distortion or more at low frequencies will, however influence one's perception of the bass reproduction of such an amplifier with these characteristics. It is important to recognize what one has chosen, whether it is the clipping behavior of the amplifier at the power levels you frequently use or the way the amplifier's distortion profile influences the bass you hear from your favorite loudspeaker.Scotty
I prefer Tubes over SS and my ears can tell the difference no matter how much rhetoric you put forth.
...and your eyes, pre-conceived notions, what you have read, memory, the price tag, etc, etc.No role telling these differences (or what was pointed out early, many[not all] tube designs significantly impact the FR)?Jim, are you stating you listen blind? Or not?
Jim do the Maggies run full range or not in your system, I can't seem to remember and it is not clear from your system listing.Scotty
Who peed in your cheerio's?
The Red Herring
I stand corrected, in the case of the McIntosh MC501, no apparent problem with saturation exists, it also has superb measured THD vs frequency at 240 watts. It appears to be without fault technically.Scotty
Gee, it wasn't me who first commented on the difference between the power capabilities of SS and Tubes. I prefer Tubes over SS and my ears can tell the difference no matter how much rhetoric you put forth. What I see here is the Silo Effect (turf wars) which is asinine. Jim
Oh please with the innocent act. You're very much a part of any "turf war", in fact you make it a point to embroil yourself in it. Again, your definition of solid state is henceforth invalid. Can't really comment on bluray players when your experience is with VCR's. Try something modern, in your system, otherwise this whole bent of "this is my opinion on solid state" is pretty much only useful in maybe the retro forum, if we even have one.
