0 Members and 1 Guest are viewing this topic. Read 4073 times.
I need to sit absurdly far back
Phasing is ok as it has been checked so many times and this has been going on through several equipment changes (amps,pre amps).TO me absurdly far back is when the speakers were 5' apart the image finally spread evenly (like a wall of sound lacking fine placement of instruments, but not skewed) at about 15' back which is not reasonable for the room usability.Also and this happens all of the time even if say a drum kit has good placement (snare seems to the right, bass toms left, hi hat right the placement shifts on a particular point in time in the music as if reflections have moved the sound to sounding like it is coming out of one speaker now, not imaging anymore. Then just as fast as it does this it can go away and the imaging seems real again.This is driving me nuts.
Is the issue random or does it always happen with particular tracks?
Saturn this stuff will drive toy crazy. Especially when you start to question your sanity.
Two problems, one solved. I did have the left speaker out of phase. Thanks for making me check again.Now to wait for the shifting of the image then unplug the pre and go direct to the amp and replay that segment. Even after correcting the phase I could still hear the center move to the left a foot for awhile then some instruments suddenly come out of position.
Saturn I did some troubleshooting and I think I am down to just being out of phase now. Whew. I read on Vinyl ladies set-ups she used Master Set on her speakers so I decided to give it a try on mine. By far the most centered I have heard vocals and I now know the importance of even pressure levels form each speaker as a tuning option. I will probably redo the Master set several times because it is fun, but for now I am getting closer to my ideal imaging on the Tektons. I can move left and right, forward and back and the sound stays almost the same. I have a spot on the right that is a bit louder, but I moved the non anchor speaker a touch and it seemed ot alleviate the issue after replaying the same bass line from Jennifer Warnes track "The Tale of the Runaway Horse."I still feel the sound is weighted left too often, but on some tracks I dont and doing A-B comparisons and removing gear when the sound is left is not conclusive of anything right now.
