Two systems, one set of subs....
0 Members and 1 Guest are viewing this topic. Read 1320 times.
jparkhur
« on: 22 Mar 2013, 07:06 pm »
Ok,
I don't know if i can do this right or if I just have to bite the bullet.  I am regulated to my man cave that has turned in to a kids cave with inwalls all around and two subs.  I would like to use the subs for the time being on both my 2 channel system and their theater.
Can I, without causing issues, hook up my subs to the Integra 40.2 and my Dodd Preamp?
Please advise... I'm guessing I will have ground loop issues or other>>...
Jon
jparkhur
Re: Two systems, one set of subs....
« Reply #1 on: 22 Mar 2013, 07:25 pm »
Nevermind... Decware switch or Khozmo extra preamp...
John Casler
« Reply #2 on: 22 Mar 2013, 07:35 pm »
I have a system(s) like that.
I have 4 VMPS LARGER subs that I use for my High Performance 2 Channel System and I add 2 more (a Velodyne and a JBL) for HT.
I accomplish it by using a XO from NHT called the X-2.
http://www.nhthifi.com/ServiceCenter/X2-Electronic-Crossover_2
It has an LFE (single) input, and Stereo Inputs along with separate volume setting for each.
You just shouldn't play both at the same time.
I heard they discontinued this model, but if you can find a used one, they are great. :thumb:
