0 Members and 1 Guest are viewing this topic. Read 5370 times.
If you can do larger corner traps, they'll go deeper in frequency.
Regarding the difference between absorbers and bass traps. It is my (limited) understanding that absorbers are full frequency absorbers (should be roughly 4" thick) or even furniture of some type. Where as bass traps are similar but with a thin membrane to reflect sound above 300Hz or so...?
I am a little more interested in a freestanding solution that can 'double' as furniture. Is there a relationship between surface area and or volume of a trap as to it's low frequency effectiveness?
Thanks Bryan,I see most panel traps are 24x48x4. I am a little more interested in a freestanding solution that can 'double' as furniture. Is there a relationship between surface area and or volume of a trap as to it's low frequency effectiveness?24x48x4 and 12x12x32 both have a volume around 4600...the flat panel does have a bit more surface area though.
I see many traps have a certain level of hf reflection designed into them. Could a large bass trap be wrapped in a paintable material (canvas, wallpaper)? It could help the trap be more 'invisible' in the space...
OK, CRAZY IDEA: what are the pros and cons of treating the entire front wall (behind the speakers)...?
Yes, it's a crazy idea because your speakers face the other way. This explains in much more detail:Front Wall Absorption--Ethan
my speakers are dipole, 20Hz-20,000Hz in both directions.
Seems to me I've read that if you pull your panels away from the wallan additional 4"....leaving an air space....it improves their effectiveness in absorbing low freq......in other words 4" can be as effective as 8"I'm sure the experts will straighten me out if I'm incorrect....I often am... Steve are you planning on covering the QRD with fabric as well?I've read this isnt a good idea...but again, lets see what the doctors say.
