0 Members and 1 Guest are viewing this topic. Read 17617 times.
That could be a worn stylus. An elliptical stylus has the shortest life span of any shape tip. It could sound like that if the mounting screws are loose, but I'd be wary. A worn out stylus can damage records.neo
neobop an atn155lc on it's way. Wow I will have a Beryllium/line contact cart soon. Any recommendations of I should install it on the Denon or Technics? I'd prefer to set it once. The at155lc/Signet will have a not too high compliance of 16 cms/dyne I believe.99.9% of the time I sell to buy, but I want to keep this DL103. I will have to see if there are inexpensive tables that would do well with this cart.Thanks.
Neobop the AT is installed. It sounds really good of course. Vocals are so real with that in your room feel. Only about 1 hour on it. I am feeling it has an edge on the DL 103 in terms of soundstage, depth, imaging and maybe a bit less amazing on cymbals, but better on piano. Great recommendation and now to keep tweaking set up on both tables. But happy enough to not want a new phono stage for now.
Not too shabby for an hour, glad it's working out. If the cart hasn't been played for a long time except for that test, it might take longer than the stylus to really sound perfect. I suspect the high end will get better as you tweak it. Is there a arm damping control? I've found that a Delrin or methacrylate mat gave me the best performance. The Boston carbon or graphite mat is said to be really good. I plan on trying one. They're expensive, the 3mm one is $200. I've never tried Herbie's mats - they seem popular. neo
It's just a better fit. The 103 was designed for much heavier broadcast TT arms. I am thinking seriously about buy a DP-62L in mint condition to try out at a good price. It would look good sitting next to my JVC QL-Y7 as they share many of the same technological advances.
Neo in any parameter I could think of the Frankenstein Signet/AT155lc - Denon Dp62l combo has surpassed the DENON DL103-technics table after about, I don't know 10 records played?
I am currently using an AT440mla on my DP-62L. Any suggestions on what would be a step up cartridge? Would the signet being discussed be the way to go? I have the Denon s-arm on mine.
Thanks for the offer raysracing! I am always afraid of borrowing a cartridge/stylus. I may consider a buy but before that I wonder if the stylus is what I should be looking for instead of the signet body. Where did you get yours? I have not been able to find one yet.
