Comet Supply
0 Members and 1 Guest are viewing this topic. Read 22428 times.
tomytoons
Comet Supply
« on: 5 Mar 2013, 04:52 pm »
FYI
Comet Supply has IN STOCK
the top 3 Denon Cartridges.
Can't beat those prices.
Ericus Rex
Re: Comet Supply
« Reply #1 on: 5 Mar 2013, 05:26 pm »
http://www.cometsupply.com/?mn=DENON
Wow!  That DLS1 price is at dealer cost!!!  How do they do it?
orientalexpress
Re: Comet Supply
« Reply #2 on: 5 Mar 2013, 06:16 pm »
Tiny said it Fall off the back of the truck  :icon_lol:
neobop
  • BIRD LIVES
Re: Comet Supply
« Reply #3 on: 6 Mar 2013, 05:06 pm »
They're grey market - not from the authorized US distributor.
That means you have no warranty, but I've read that Comet will replace a defective cart.  It happens, and in one case somebody got a very old sample that looked like it was previously returned.  If Comet stands behind the sale, you wouldn't have much to worry about.  Usually a cart either works or not.  If it's a model worth re-tipping or repairing, you don't need the mfg for that.  Trade in might be a problem.
neo
tomytoons
Re: Comet Supply
« Reply #4 on: 7 Mar 2013, 12:38 am »
Well you are correct, but if it has an opened box that is the first indication it may be used.
I have never read of anything you state as complaints.
I have a Denon DL301 MKII on the way.
We'll see.
I have purchased a DL103R in the past and no problems all sealed new.
John Ellison on Audio Asylum has purchased 2  DLS1 with no problems.
neobop
  • BIRD LIVES
Re: Comet Supply
« Reply #5 on: 7 Mar 2013, 02:03 am »
I think it was on Karma, someone got a defective cart with an old serial number.
Comet replaced it.
neo
PierreB
Re: Comet Supply
« Reply #6 on: 7 Mar 2013, 02:35 am »
vortrex
Re: Comet Supply
« Reply #7 on: 7 Mar 2013, 02:58 am »
I bought my Denon there, it arrived in a few days, new in the box, and has worked great.
tomytoons
Re: Comet Supply
« Reply #8 on: 7 Mar 2013, 03:24 pm »
In the past I had another cartridge on order waited 1 month, called and cancelled my order, refunded immediately via phone.
I'll post what happens on the order this time.
Update>
Shipped today, 3-8-13
« Last Edit: 9 Mar 2013, 12:27 am by tomytoons »
tomytoons
Re: Comet Supply
« Reply #9 on: 11 Mar 2013, 07:33 pm »
The Denon DL301 II came in today, absolutely fine.
J-Pak
Re: Comet Supply
« Reply #10 on: 12 Mar 2013, 03:47 pm »
I bought a 103R from them a long time ago. Cart appeared new and was fine.
a.wayne
Re: Comet Supply
« Reply #11 on: 19 Mar 2013, 01:58 pm »
Order placed on the 14th , we will see .....
Jeff V.
Re: Comet Supply
« Reply #12 on: 20 Mar 2013, 12:00 pm »
Ordered a Denon DL-S1 last week.  I checked order status yesterday. I was happy to see a Fedex tracking #.  Delivery will be this Friday!  When I purchased the Denon, the Comet webpage did show the item in stock.  I'll post my impressions of the DL-S1 once broken in.  Currently using a Ortofon Jubilee.
Jeff
mgsboedmisodpc2
Re: Comet Supply
« Reply #13 on: 20 Mar 2013, 09:52 pm »
Jeff V.  willo you be using a SUT with the denon and if so which one a 1:40 (32 dB gain) Sut
Jeff V.
Re: Comet Supply
« Reply #14 on: 20 Mar 2013, 11:47 pm »
I have a Cinemag 1131 that should work good with the Denon.  With my Ortofon the 1131 sounds great but has a bit too much gain.  Should be a great match with the Denon.
Jeff
a.wayne
Re: Comet Supply
« Reply #15 on: 21 Mar 2013, 03:28 am »
Jeff
Interesting , they are telling me after april 1st for the DL110 .......
a.wayne
Re: Comet Supply
« Reply #16 on: 21 Mar 2013, 03:49 am »
Any thoughts on a DL301mk2 , i will see if they have instock and  upgrade if they do ....
Jeff V.
Re: Comet Supply
« Reply #17 on: 21 Mar 2013, 04:19 am »
I waited to order the Denon DL-S1 until it showed in stock.  I just checked the Comet site & the S1 & DL-304 are the only models in stock at this time.  I can't comment on wait times for items not in stock.  The DL-304 is a nice cartridge but a bit more expensive than the DL-110 & 301MK11.  Good luck.
Jeff
a.wayne
Re: Comet Supply
« Reply #18 on: 21 Mar 2013, 02:56 pm »
Is the 304 worth double the cost of the 301 ..?
tomytoons
Re: Comet Supply
« Reply #19 on: 21 Mar 2013, 04:01 pm »
I have the 301 II did not use it yet. Is the 304 worth twice the price?
Don't know. Maybe check on comments on the "Asylum".
My question is it as good as my Dyna 10X5?
