0 Members and 1 Guest are viewing this topic. Read 4800 times.
Yes, the 400's, plugged into a wall receptacle, will also benefit other devices on that same circuit, but high-powered amps should be plugged directly into the wall, and low-wattage devices plugged into the receptacles on the 400's. The 400's together can easily supply all your front end, including TV, DVD, pre-amp, CDP, turntable, etc. I was being a bit conservative when I said only one item per 400s, because I had the original models, not the Pro model. Yes, they are min-transformers, in that they supply wattage, but not enough for sustained power, as I understand it. Look for deals on 'gon for new units. MRC, probably best not to insert a power strip between the 400's and the wall--direct is best. Heavy tranformers trump power strips.
