Stepup Transformers. What do you use?
0 Members and 1 Guest are viewing this topic. Read 37771 times.
zuluwarrior0760
Re: Stepup Transformers. What do you use?
« Reply #80 on: 2 Nov 2014, 04:17 pm »
My prior turntable/cart combo was a VPI Classic 3 and Lyra Kleos....
The phono was the phono section of my Convergent Audio Tech SL1 Renaissance w/ Phono...
In comparison with other tables I listened to and my digital rig, I noted
a laid back darkish presentation......I did the VPI 3D Arm and that put a soft
edge on the presentation.....
So I scrapped everything but the cartridge and got a Merrill Williams REAL101.2
and an Ortofon TA210 arm with an Arche' adjustable headshell.
With the Kleos installed, the noise floor was lower, but the character was the same.....
I sold the Kleos and got an Ortofon Cadenza Black and that improved the presentation
tremendously, but overall the presentation was still laid back compared to what I
wanted.
Upon my dealer's advice, I went beyond the various Bob's Devices transformers
and went with a Hashimoto based transformer.  The most recommended ones
are from Choir Audio, but after 5 attempts and no callback from that guy,
I went to find other options.  I found out that the U.S. importer for Hashimoto
produced SUT's as well for about the same cost.  I went with the HM7 instead
of the HM3 based on his advice.  I disabled the internet SUTs in my preamp
and hooked everything up and the most noticeable thing was the increase
in gain.....it was dramatic.....the second thing I noticed was increase in
detail and increase in the air between instruments etc.  I will say that neither
the SUT nor the cartridge have more than a handful of hours on them as of
now, but knowing what I have learned up to this point, I will say that my
analog rig is fairly well where I want to be for a while........it obliterates
the previous but I will say that I may have experienced similar results
going to the Ortofon and Hashimoto HM7 on the Classic 3.  There is
no question that the Merrill Williams is a much better turntable though....
BTW:  The Hashimoto SUT I bought was from a company called Sound Tradition
www.sound-tradition.com
vortrex
« Reply #81 on: 2 Nov 2014, 04:49 pm »
I also have the Sound Traditions Hashimoto based HM3 and HM7 units.  They are incredible.  The units are hefty, unlike the rinky dink Auditorium 23 and Bob's Devices.  I'll be replacing them next week with a purpose built unit (Miyajima KSW) for the carts I am using now.
Still amazed that more people don't use SUTs.  It's the single best upgrade you can make.
zuluwarrior0760
« Reply #82 on: 2 Nov 2014, 05:07 pm »
Step up transformer shown in following video:
WARNING:
This video contains music by Jazz singer Diana Krall.
If you have any disorder that might make you more
prone to periods of spastic vomiting please click with
caution:
www.youtube.com/watch?v=ctaIWCcz9LQ
vortrex
« Reply #83 on: 2 Nov 2014, 05:22 pm »
Looks like the video is unavailable due to poor taste in music.
orvisk
« Reply #84 on: 28 Mar 2015, 06:32 pm »
I currently am using a v15 III with a tubesforhifi pas 3 with plenty of gain; however- prior to this system I was using a low output grado sonata(.3 mv I think) with an audible illusions 3a moving coil gold boards installed in the chassis.  I would like to use the grado with the pas3 but need a sut and I'm not knowledgeable about this.  Anyone have any recommendation for a correctly-matched sut?
orientalexpress
« Reply #85 on: 28 Mar 2015, 07:08 pm »
using a pair of peerless tranny would be fine. :thumb:
lapsan
