0 Members and 1 Guest are viewing this topic. Read 37564 times.
Don't know how we got so far off course. The thread initially was about using stepup transformers as a gain stage for MC carts . . .Those that are happy with the built in gain stage in their all in one phono pre, please do not be insulted by those of us who like to experiment. That you are happy is wonderful, the initial post was not to try to persuade anyone to try to use transformers, but rather, to ask those of us that do, what they use . . .
All MM i know of still have gain. I would not consider them just an EQ.
Well I've never used a MC cartridge for the following reasons:1) Never owned any.2) Tracking of most MC's is usually 3 g. which is enough tons of force to wipe the record after two or three plays.3) Use of transformers into the MM input gives normal RIAA Eq. that can't be bypassed, but the impedances seen forward affect the frequency response depending how badly or goodly the MC Cartridge is loaded. Most MC's are supposed to be loaded with 100 ohms, instead of 47K ohms, if I recall from some 30 years back.Steven, I have never had an MC cartridge that needs a 3 g tracking force. I have an AT OC9 (1.6g), AT33PTG (1.8g) and a Denon DL-s! (1.3g)M4) Don't have any MC level inputs, modern stuff doesn't even have MM phono inputs.Still, Mike, if I get the drift of what you're saying, maybe I should hook up some small shielded transformers, connect up my MM cartridge(s) and turntable, and try that into my normal PAS-3x Preamp, or my slightly modified PAS-3x (both use 1960's Telefunken 12AX7 tubes) or one of many transistor preamps. However, since the PAS is tubes, it has a wide overload capability, and I think I once measured a PAS as putting out over 30 volts P-P before clipping, then I'd get the so-called advantages of "Input Transformers" and none of the Moving Coil Cartridge "minuses". Anything close to 1:1, or between 1:1 and 1:4 or 4:1 would probably work. Hooked up after the PAS could be any half decent receiver, Mosfet Amp, ULT Amp, SET Amp, etc. and usual speakers system.So does this sound like a good idea? Anybody ever try this? Chirp in with suggestions!-Steven
I use a Hagerman Piccolo that I have modded and upgraded. It powers my Transfiguration Temper LOMC cartridge into a Hagerman Trumpet MM phono stage (but you know this already Mike).Is it the quietest step up/head amp? No, but it has lots of adjustability for loading and gain (I need 26db boost for the .2mv output of the Temper) and has rediculous performance for its cost. I would love to compare it against the better Bob's devices or Slagel's or Jensen's. I have heard it vs the venerable TX103 transformers and thought it was better all around. More dynamic, better soundstaging and imaging, better bass and transparency.And I have pride of building it myself and experimenting with different caps and resistors in the signal path to tune it to my ear. Not something that can be done with a transformer.
My experience was completely the opposite. I have tried the Piccolo with the Trumpet, and tried it with the TX103 copper that came with the Trumpet, and I thought the SUTs were not only better, but simply much better. I think you are doing a disservice to your top-flight cartridge by running it into a Piccolo. Just my opinion.
I have a feeling you could be right, which is why I am eagerly awaiting the results of the stepup shoot out that I think Topround is (likely) preparing.
Yes, a step up shootout is in the works. It is not exhaustive though, just the usual suspects who wanted to be involved.I am not involved in the review I am just the instigator of it.They will all be wound for the same cartridge.Should be interesting, look for it on Analogplanet.com shortly.I would like to know more about the different incarnations of the TX 103, is their a history path of changes to this transformer? Was never impressed by the TX 103, perhaps I heard a bad one?Would love to know more
How about keeping it simple and stick to what the manufacturer recommends keeping personal preferences out of the equation.
