0 Members and 1 Guest are viewing this topic. Read 12368 times.
yeah,I've been all over that site. The box plans have no dimensions and no xo info. http://www.visaton.de/en/bauvorschlaege/breitband/solo100/bauanleitung.htmlThere are dimensions (sketch )and XO schematics for each kit . On the right side click on construction and it will show you XO on the bottom and all dimensions you need . Dimensions are all in mm
The A8s were 20" x 11" x 14.5" and used 2 of these: http://www.madisoundspeakerstore.com/flares/ports/vents/scanspeak-290001-aperiodic-vent-ssv/
I did find an Australian who built a similar enclosure but with a rear vent, not Aperiodic....
Are you talking about Joe's as linked above? It is aperiodic.dave
Are the vent locations critical? Driver location critical?
FWIW A long time ago I put mine in a 3 cu ft box and while they sounded okay I feel they beg to be used ob and there are a vast number of fullrange drivers that work much, much better in a box.
That one is just weird. Cabinet as auxilury bass radiator. All that work and he didn't bother rebating the driver? The filter looks like BSC.
That one is just weird. Cabinet as auxilury bass radiator. All that work and he didn't bother rebating the driver? The filter looks like BSC.dave
OK, please see attached first draft of my enclosure. After getting a few pointers from Louis at Omega, I have drafted this based on the Omega A8 dimensions.The driver will be run without any crossover -- the driver had a phase plug from Planet 10.See attached link for reviewed finished speakers:http://www.6moons.com/audioreviews/redwine3/system.htmlI was hoping to have a couple people more educated then myself to chime in on the basic design. I'd hate to make an obvious rookie error. I won't be starting this project until March, so no rush. The basic enclosure has a 2-ply front baffle for strength and screw depth. The driver is recessed into the front baffle. There is a single H-Brace with holes mounted below the centre of the enclosure. The vents are evenly spaced on the rear.Thanks again for looking.
This speaker use a similar aperiodic project:http://www.youtube.com/watch?v=anGQEQ7JB1cOr looks to be the very same.
