Crossover 10B LR
0 Members and 1 Guest are viewing this topic. Read 2428 times.
JBLMVBC
Crossover 10B LR
« on: 29 Jan 2013, 01:46 am »
Hi James,
out of curiosity, I noticed that the crossover 10B can be combined for a 4 way active system (three or four units configuration).
What is the retail price for the 10B LR?
Would the frequencies have to be submitted beforehand for the Linkwitz-Riley version?
I am using two Rane active crossovers and am quite satisfied with the sound. What is the difference between the Brystons and Rane's designs?
Thank you. :)
  • The Demo is Everything!
    • http://www.bryston.com
Re: Crossover 10B LR
« Reply #1 on: 29 Jan 2013, 01:50 am »
Hi James,
Thank you. :)
Hi
It can only be configured for a 3-way MONO.
james
JBLMVBC
« Reply #2 on: 29 Jan 2013, 01:53 am »
« Reply #3 on: 29 Jan 2013, 02:22 am »
Yes but you would have to use 2 crossovers to get a 4-way output.
james
JBLMVBC
« Reply #4 on: 29 Jan 2013, 02:31 am »
I understand James, that's what it looks like. Any comments on my other questions? Thanks.
« Reply #5 on: 29 Jan 2013, 09:58 am »
Hi
The 10B is a fully discrete Class A circuit (no IC's) so sonically I would think you would find the sound much better.
James
cheap-Jack
« Reply #6 on: 29 Jan 2013, 04:18 pm »
Hi.
Hi
The 10B is a fully discrete Class A circuit (no IC's) so sonically I would think you would find the sound much better. James
Yes, discrete active devices always sound than IC chips. Same for preamps & power amps.
c-J
JBLMVBC
« Reply #7 on: 29 Jan 2013, 09:35 pm »
Thank you for the comments. And 10B retails at $$$?
« Reply #8 on: 30 Jan 2013, 12:20 am »
$3595 List
james
JBLMVBC
« Reply #9 on: 30 Jan 2013, 12:48 am »
Thanks James.
Are the Linkwitz Riley frequencies fixed i.e. chosen upon client's request or can be changed through the front knob like in the normal version?
« Reply #10 on: 30 Jan 2013, 01:25 am »
Thanks James.
They plug in to a board so they can be soldered in or you can use a small plug in so you can change the crossover frequency if you want.
James
JBLMVBC
« Reply #11 on: 30 Jan 2013, 03:26 am »
Thanks James, appreciate the info.
