0 Members and 1 Guest are viewing this topic. Read 11456 times.
How do you tie a knot in the thread without having the knot become a bump in the belt?
Interesting about using thread rather than rubber belt. I'll give it a try on the Kuzma Stobi S. I'm concerned about slipping using the thread approach as opposed to the rubber belt. Uses a stand alone motor so it can be tight but not sure. Any comments appreciated. Sounds like a good experiment.charles
I don't see how a thread would work with a TT with a fixed distance between motor and spindle unless the TT was designed to be used with a thread. How do you get the right tension--by significant trial and error? I have had no problems keeping my platter speed accurate with the belt supplied by SME. When SME can command the money it costs for one of their TT and receive the consistent outstanding reviews across the globe, I am going to assume that the belt they supply is the right way to go.Laura
I've been using silk thread for years now. I would never go back to the VPI rubber O ring. However, depending on your motor capstan, you may need a speed controller.Cotton thread stretches, so don't use that. Polyester thread doesn;t stretch, and will give you a brighter sound (thread affecting tonality? Yeah, somehow it does.) Silk thread also doesn't stretch and has a more organic souond. Try different guages for different results.Here's a link to a cheap online source:http://www.artbeads.com/stringing-materials-griffin-silk-bead-cord.html
what you want to look for is a material that will not stretch. The polyester blends are good, and like the sound from Rayon and Dacron as well. Silk worked well, but lacked some bass extension for me. On the other hand I felt the upper end of the scale was a little more open and transparent. The thread dosn't seem to transfer as much feed back from the motor as the other does. The thread is so cheap that you can afford to experiment. And while on the feedback subject, try to make a vibration isolator pad for the motor. This really opened up the high end with a Grado or D103 (specially the Denon). Rubber drive belts go bad from sunlight alone, and will stretch to no end.gary
