Phono cable requirements?
0 Members and 1 Guest are viewing this topic. Read 1247 times.
greg7
« on: 28 Jan 2013, 02:14 am »
Does a phono cable need any special LCR requirements? I'm referring to the cable between the turntable and phono stage, of course. I'm thinking low capacitance, for example. I use Cardas interconnects (300B Microtwin and Crosslink). These aren't low capacitance cables. Are there any issues using these?
neobop
  • BIRD LIVES
Re: Phono cable requirements?
« Reply #1 on: 28 Jan 2013, 04:44 am »
If you're running a MM it's a good idea to keep the capacitance low.  Many modern MMs want to see a total shunt capacitance of < 300pF, and some < 200. That's preamp + cables + internal arm wire.  Blue Jeans makes low capacitance cable that's 12.5 pF/ft (I think).
With MCs capacitance doesn't matter as much.  I've seen low inductance arm cables for MCs, but it's uncommon.  Always a good idea to keep runs as short as possible.
neo
Miney
  • Free your mind... and your ass will follow
« Reply #2 on: 28 Jan 2013, 10:56 pm »
Check out the Cardas all Litz coax available from KAB:  :thumb:
http://www.kabusa.com/wirewin.htm
roscoeiii
« Reply #3 on: 28 Jan 2013, 11:06 pm »
Audience suggests that phono cables should be matched to the impedance of an MC cart. So they sell a one cable intended for low impedance MC carts, and another for high impedance MC carts. They also have a different cable that is best suited to the needs of an MM cart.
You can find the details in reviews of their phono cables and in their promotional literature.
