0 Members and 1 Guest are viewing this topic. Read 12343 times.
All true.... as long as you have a monitor. Without menu navigation on a monitor, you can't do anything except play CDs / SACDs and switch inputs. Fine for a system with a TV, but a PITA for a music only system.
The question mark for me is how well it would function as a preamp. But I am a preamp guy who hasn't had much luck with passives or DACs with volume control in comparison to when my preamp is in the chain.
I use Jriver software and Jremote app for ipad - no monitor needed.
An app for Apple iOS devices is coming soon.
I am sure Dan can answer this if it posted on the modwright forum.
It will likely depend on how the volume control is implemented. But the output impedance doesn't raise any concerns.You might want to check the huge Oppo 105 threads on AVS forum or SH forum to see if anyone is doing this there.
Sorry, but I wonder if you can tell me what SH forum is?
I have a BDP 105, and I quite like it a lot. It performs well as a DAC, supports streaming from a NAS box, music and netflix services, etc. The only thing is, if it were me, I would use something along the lines of a First Watt B-1 buffer between the Oppo and the power amp(s). Best to have the Oppo output full bit resolution, and use a passive buffer to isolate.
True if you are using a PC or music server to feed one of the Oppo's USB/HDMI/SPdif inputs. But if the plan is to use the Oppo as a stand-alone squeezebox-ish music server/streamer without a computer, you have to have a monitor to navigate the control menus with the remote. No way around it at this point.
