Is Oppo BDP-105 The Best DAC/Pre Option For Me?
0 Members and 1 Guest are viewing this topic. Read 12349 times.
Russtafarian
  • Typical reaction to the music I play
Re: Is Oppo BDP-105 The Best DAC/Pre Option For Me?
« Reply #20 on: 7 Feb 2013, 07:18 pm »
You may use a controller application such as Foobar and push music to the Oppo via the ethernet or wireless port (using the player as a renderer) without needing a monitor.
True.  I got this to work using Jriver as the player and the Oppo as the renderer.  But it was a pain in the a$$ to get it working and keep it functional.  I had to use a monitor to set up the Oppo as a DLNA network renderer every time I wanted to listen this way.  Then getting the Oppo to show up in Jriver as a renderer could take up to 10 minutes.  Once working, track selection, start, stop, skip functions could take around 5 seconds to execute.  And this was with 16/44 bit rates.  Hi-rez files had to be downsampled to lower bit rates to work.  Then to release the Oppo from renderer mode in order to play a disc required restarting it.  I was using an ethernet connection for both the computer and the Oppo, not wireless.
I'm new at this DLNA stuff so some of this might be due to my incompetence.  My network might not be optimized for DLNA over ethernet, though I never had a network issue streaming music (even 24/192) though a Squeezebox Touch.  Based on my experience and what I've read, streaming music via DLNA is not ready for prime time unless your cool with MP3 bit rates.  I'm not trying to rain on anyone's DLNA fantasy here, just trying to give a realistic glimpse at what to expect.  If someone can get this figured out and working smoothly with hi-rez, high bit rate music files, please let us know how you did it.
I will say that if you can get the PC close enough to the Oppo to connect via USB or HDMI, that works really well and it's what I use all the time.
Russ
JeffMO
« Reply #21 on: 8 Feb 2013, 02:27 pm »
Sorry you have had problems. I have been streaming lossless Flac over wireless (802.11 G network), including some 24/96 and 24/88 files, without any issues whatsoever. I also have a Touch on the wireless network and it likewise functions flawlessly. I am able to seamlessly switch between playing discs and streaming music. I do prefer the Touch because of support for gapless playback, but the Oppo works fine.
Sounds like you have issues with your network or controller configuration.
Russtafarian
« Reply #22 on: 8 Feb 2013, 06:05 pm »
Jeff, if you have some suggestions on how to set up or optimize my network for DLNA streaming, please PM me.  Thanks.
