0 Members and 1 Guest are viewing this topic. Read 5587 times.
The only drawback I see to the loft is being open on one side - though the pictures make it look like it's not really open - just a hall on one side and open behind?Bryan
I'm thinking the loft should be able to sound pretty good. How about setting the speakers across the full wall corner. Your chair would be at the corner of the half walls.A pic of the corner of the half walls would be useful.Do you live alone?
I like the loft too. I didn't read too closely but what is the distanced from your ears in the chair to the speakers. What is the distance between the two speakers in the loft set up? What is the distance from the front of the speakers to the big wall behind the short wall. I think it is the Cardas website that has the "Golden Triangle" set up measurements that the loft will lend itself to very easily. Follow the guide.
