0 Members and 1 Guest are viewing this topic. Read 5597 times.
I know you indicated using the Great Room is not an option, but if the issue is all the ancillary equipment that would be strewn about, here's an option. Since your loft is open to that room, could you place the equipment in the loft and only have the speakers downstairs? What with remotes and music servers, you should be able to control most things with a remote.I don't know the size and shape of that room, but it must be larger than the loft or bedroom. I know you want to keep the equipment you have now, but speakers designed for placement close to a back wall would further reduce the instrusiveness of the system into that room. Just a thought.
