0 Members and 1 Guest are viewing this topic. Read 17391 times.
I will say, I never knew how good bass sounded until I measured my system and filed in the EQ. I'm buying a new mic setup from PE, the one on back order for sale. Once you start down this path, I'm not sure you can turn back. Good bass response and integration is a bitch but its worth it. CheersJack
Cross Spectrum will have the Dayton UMM-6 with USB output around the first of Feb. It will come with calibration files in the FRD format. The cost listed on the website is $90. If the REW program is compatible with FRD format calibration files then the cost of measurement is considerably less than I originally calculated. An inexpensive mic stand later and you're business. I knew I was dragging my feet on doing this for some reason.Scotty
Pretty much what I expected. If you have never taken measurements you have NO IDEA what it should sound like. A little bit of science goes a long way but you're clearly not interested in that.
Jim,Maybe it was the quality of the bass from the subs you didn't like. I can see how 40hz from a panel like the Maggies could sound very different from 40hz from a coned sub. Maybe no amount of integration could have remedied this for you.
Perhaps one of the unrecognized factors governing the sound of a sub-woofer is the built amplifier driving the sub and the power quality going into it. In my system the sub-woofer that I have operating at the rear of the room had noticeably sluggish response compared to the main loudspeakers in the front of the room. The amplifier driving the front speakers is plugged into a 17amp rated FELIX power filter. The sub in the rear was being fed from the wall. When the sub in the rear was plugged into another 17amp rated FELIX filter the sluggishness disappeared and its output matches closely the front speakers. The crossover in the rear is set for 60Hz and is 12dB/oct. The point being that the decision to add a sub to any loudspeaker and the results you may get are dependent on more factors than you may have realized. In my case no amount of repositioning the sub, changing its output level and phase or the cross-over point, changed the type of sound the system had when the sub was on. It took matching the power filtering on the sub-woofer to that of the main amplifier the make the bass quality from front to rear the same. Measurement might have shown what was happening but it wouldn't told me what do about it.Scotty
I have "old school" measured my system with a test cd and a RS digital meter. Not a perfect way, but if anything was out of kilter it would have shown it.
The problem with typical test tone CDs is they play only the standard 1/3 octave frequencies. The graph below shows the response at the listening position in a typical bedroom size space. Note the peak/dip pair at 110 and 122 Hz where the response varies a staggering 32 dB across a range smaller than one musical whole step. This behavior is completely hidden when measured at 1/3 or even 1/6 octave spacing.A similar problem happens when assessing by ear because music contains only certain frequencies related to the key of the piece. So if your room has a strong resonance or a severe null at 110 Hz (key of A), that won't be heard when playing music in another key that doesn't contain that note.Likewise, test tone CDs don't show modal ringing, individual reflections, or RT60 versus frequency, which are just as important indicators of fidelity. I'm all for listening! But measuring tells you everything you need to know in less than one minute.--Ethan
I've been to enough "Live" Concerts and Events to have a real good grasp of what Bass is supposed to sound like and the 20.7's were able to deliver the goods without subs. I didn't need fancy measurements to confirm what I already knew to be fact. If I were having issues that I couldn't resolve by trial and error placement, then it would behoove me to take measurements to isolate an issue(s). My posts were not a condemnation of measuring and to those who do. The responses I received speak for themselves. I too tend to think that Magnepan is conservative in there measurements, but understand, they are taken in an Anechoic chamber. Each room will have its own set of issues. Let's move on, please. Jim
If I didn't like what was hearing, I would invest in the technology to measure my system. Sometimes, ignorance is bliss. While, you make a compelling reason for full on measuring, there is no guarantees that it would show aberrations from the normal.
