0 Members and 1 Guest are viewing this topic. Read 3999 times.
How long did you wait? Even with the latest iPhones and iPads, IOS 6 is a very large, very time-consuming upgrade. It appears to be hung at several points, but it is still going.One way to know is if you have an indicator on your PC that lights with disk activity -- as long as nothing else major is going on, if the disk light is flashing madly, iTunes is still working on your update.I think it took a couple hours when we did our iPad, even with a very fast internet connection, before it got completely finished.
Anytime I have a problem with my phone,Ipod or Itunes I get my 17 year old nephew to fix it, go figure.
I don't want to assume anything but should we accept that you have your phone connected to your computer and you are running iTunes for the upgrade? If so, there is a button to restore to an earlier version of the OS.
Phil are you using a wired connection to your computer for the upgrade?
Well, no luck with mine on the other machine. I did have a backup of the iPhone on that machine but you can't restore from it until after you do the update. Bleah. Maybe it's hammer time for this one.At least I was able to get an iTunes remote onto my Nokia N9. So it's not a complete disaster. Hi ho.
