0 Members and 1 Guest are viewing this topic. Read 12664 times.
This has been puzzlingly me for some time. 2 3.7s, 2 DWMs and you still need one or two subs if you want to go low. That is a lot of speakers, too many INMHO.In my room I now have a pair of 1.7s (had 3.7s) and feel that slight Maggie leanness in the mid bass area. I also often feel the need for a sub or two. However, I don't see the logic of spending a ton of money and added complication. Remember that each additional speakers require interconnects and troublesome placement problems.Guys if Magnepan wants to correct the deficiencies (slight but noticeable) inherent in their speakers design, they need to go back to the drawing board. I always told my students that when things start to get to complicated it is time to step back and fix the design.
I have been told that the bass from the Tympani is the gold standard for the Magnepan line...how does it compare to the 20 or 3 series?
I have two pairs of 3.7’s as surrounds. When in all channel stereo mode (theoretically the same stereo signal to all pairs of speakers), one pair will have a definite difference in performance. Even Audyssey Pro calibration set their crossovers and different points. I would have thought that since both pairs are identical the crossovers would be the same. It must be their positions in the room that are making the difference.
I can relate to the things popping up - my refrigerator is now the back porch. Good thing it's wintertime.You should have sufficient bass with the 20.7s and I suspect you will be off the speaker upgrade merry go round.It's off to the doctor for me, this sinus infection just will not go away.
The reviews say it's still better.To put it in perspective, the Tympani midbass is pretty universally reckoned (by those same reviewers and by Wendell himself) the best of all time.Wendell says though that he's been able to get midbass comparable to the Tympanis on the single-panel models by adding DWM woofers, and he's going to be doing a demonstration at CES to prove his point -- DWM's vs. Tympanis.
Neil or Rite Aid sinus rinse twice a day. My left sinus had a habit of becoming infected every winter for more than a decade, then I started using the sinus rinse and no infections for about 5 years now.
Jim- Don't know how many of you great sound enthusiasts have had your doctor clean your ears, but I was mazed at what came out of them. Looked like .22 caliber bullets. Getting into my car afterwards, the rain hitting the roof sounded quite different and the newpapers I had covered the carpet with did, too. I was so amazed I went straight home (before returning to work) and listened a very good recording of some Bach and could clearly make out the dome of the church in which the recording was made for the first time.
Maybe I should try that....right now my right ear is giving me problems, feels like the right side of my head is listening in a fish bowl. I usually can alleviate it by using ear wax removal solution for several days....Jim
Jim:I've suffered from sinusitus for too many years and the associated pressure in the sinus cavities usually leads to wax build up. I use prescribed medication for the nose and have had my ears roto rootered by my Dr...he is the one who told me to save the co-pay and to use an earwax removal kit. Yes, the difference is day and night expecially in the upper frequencies. All that aside, I'm open to anything that will work...Jim
My doctor told me to use a few drops of baby oil in each ear. Turn head sideways, insert a few drops, wait about a minute, turn head to allow the baby oil to drain, finally use a towel to dry ear and remove wax. Repeat with other ear. The doctor also said that a gentle flush with warm water would also be useful. Twice a week.
The midbass on my T-1Ds was awesome.Is anyone going to CES?Has anyone seen a picture of the larger single-panel models with DWMs?From Magnepan website:"Most of the area of any full-range Maggie is devoted to bass reproduction. (In the case of the 20.7, 76% of the total radiating area is devoted to bass.)"If the same percent applies to the 3.7, then a 20.7 has about 34% more bass radiating area. It looks like a 3.7 with a DWM would have the same bass radiating area as a 20.7 for a lot less money.
It's a good thing I didn't say stomach issues.It's bronchitis, what fun. I gave it to the Mrs. who got the beginning stages of pneumonia.Okay, back to this 3.7/DMW combo...
What are DWM's ?
I used to go to the ENT once every couple of years, but not so much lately. There are some medical professionals that feel occasional removal of ear wax with various implements should be avoided and that regular maintenance/removal with various solutions is the best method.However, once it builds to a point, the only quick way to remove is a trip to the doctor. When you have your ears clean, keep them clean. A drop or two of mineral oil every once in a while inhibits ear wax production, and it's a good idea to put some ear-removal drops in occasionally to clean out what's there. A few drops in the evening, and then a flush in the shower the next morning.Regular ear cleaning will improve the bass output of your 3.7's. Cheers,Dave.
