0 Members and 1 Guest are viewing this topic. Read 12654 times.
Maybe Kevin wants to try the DWM's? He doesn't have enough space for 20.7's.
I have to ask – what are the dimensions of said room?
I sometimes feel my 12 year old 3.6´s had more bass than my current 3.7´s, butperhaps they are not broken-in yet.....or will the 3.6´s really go lower?
Seems to be !Frequency response measurements on axis in an anechoic chamber of the 1.7 and the 3.7 donot show the distinct bump of the older models (1.6, 3.6) in the mid- to upper bass region.But the fr of both speakers descend around 40 Hz and confirm the manufacturer's specifications.
I think that's what they're getting at - you can fine tune the bass in your room with the DMWs.Wendell did say they were getting into the low or mid 20s (Hz) with the 3.7/DMW combo at the show.
According to the Magnepan website the frequency respones of the 3.7 is: 35 Hz - 40 kHzThe frequency response of the DWM bass panels is: 40 Hz - 200 HzThe combination of both would give an additional boost to the mid/upper bass and the lower midrange region - but do not add anything to the bottom octave.
