0 Members and 1 Guest are viewing this topic. Read 4467 times.
Going from a $700 setup to a $9500 one....quite the jump!!
Go big or stay home!
Thinking of upgrading my TT. I've got a Music Hall mmf-5 with the Goldring cartridge it came with.Have the SS8's and a Wyred 4sound ST-500. Just trying to improve sound in all facets. I defintly prefer a warmer sound.Is there a cartridge upgrade for this TT that will do the trick?What do you all like with the Salks?
My TT experience is VERY limited, but I can certainly say that my Rega P3/24 with an Ortofon blue is a great combo with the Salk ST's. What is it about your current TT sound that you are not happy with?
My first table was a MMF 5.1, then a Pro-Ject Xperience Classsic, highly modded Rega P5, VPI Classic, and finally a Well Tempered Amadeus. The WT easily beats any of those tables. A Simplex is supposed to be very close to the sound of an Amadeus but at a lower price point. Since WT USA is in St. Louis it should be easy for you to check them out.
stlblues, what phonostage are you using? How much are you looking to spend on an upgrade? Have you looked at the Dynavector 10x5?
There are two good Amadeus deals on audiogon now, one in your area.
